Mobil 1 changes?
Also the oil recommendation is for NEW cars. Note the different oils for other years. Do you think GM calculate a recommendation oil for a 27 year old engine wear and tear. Heavier oil will fill in the extra space from a lot of miles. You also have ambient air temperature above 70 degree at all times for the next few months. If your oil pressure is low you'd may want a slightly heavier oil. What's you oil pressure?
High mileage oils have additives to swell seal. May stop a leaking seal but will cause good seals to leak. How many miles does your car have?
You won't drive enough miles for a difference to be seen and are better off putting your energy/$ into making sure you have a working cooling system, looking for leaks, flushing brake fluid, and reducing cold starts/ short drives will pay off.
I prefer Castrol for technical reason I can't remember right now but really I buy the brand on sale that meets the API standard.
Oh, and insuring the oil filter is filled with oil prior to installation, the old oil is fully drained, and not running low oil levels will do more protection than which brand.
