Darnedest steering problem - rack moving
Old Jul 19, 2020 | 05:15 PM
PacerX's Avatar
PacerX
Default Darnedest steering problem - rack moving
So I installed a rebuilt steering rack, replacing the bushings with polyurethane.
Now, there's enough slop at the driver side through bolt that the ENTIRE RACK is moving side to side when turning the wheel. I'm going to go back and re-torque, but it looks like the driver side bushing is moving inside of the rack itself. The passenger side donut bushing is doing jack squat to stop it.
Anybody run into this?
Old Jul 19, 2020 | 05:29 PM
don hall's Avatar
don hall
See if this video helps:
Old Jul 19, 2020 | 05:44 PM
PacerX's Avatar
PacerX
No, but thank you. I probably didn't explain this well...
There's no problem with the rack, there's a problem with how it is interfacing with the body at the mountings.
The problem is that the entire rack is moving - housing and all. The pinion part is doing what it is supposed to do, but the housing is shifting on the mountings. The only thing I can figure at this point is that the driver's side bolt isn't tight enough, or the hole where the bushings go is too large, or the bushings are too small.
Old Jul 19, 2020 | 05:50 PM
ChumpVette's Avatar
ChumpVette
Did you forget to put the insert in with the bushing?
Old Jul 19, 2020 | 06:12 PM
PacerX's Avatar
PacerX
No, it's there. Weird...
After some more investigating:
The bushing is moving around inside the hole in the rack. There's a little slop due to the fit between the insert and the bolt, but most of it is coming from the fit between the bushing and the rack.
So... either the bushing is wrong, or the rack is.
Neither of these options are particularly appealing.
Old Jul 19, 2020 | 08:15 PM
ChumpVette's Avatar
ChumpVette
Where did you source the bushing?
Old Jul 19, 2020 | 08:44 PM
PacerX's Avatar
PacerX
Prothane.
Old Jul 20, 2020 | 10:21 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Do you still have the old rack ? If so measure it. Of course to determine where the discrepancy is, you will need to measure the new(rebuilt) rack also. Then you will know if it is the rebuilt rack or the bushings.
Old Jul 20, 2020 | 10:30 AM
PacerX's Avatar
PacerX
I do and that looks like the plan.
Would not be shocked if either the rack or the bushings are wrong.
This suspension rebuild has reinforced what a clown show the aftermarket is... And I am using top shelf parts across the board.
Old Jul 22, 2020 | 08:15 AM
PacerX's Avatar
PacerX
OK, tore it down yesterday, at least enough to pop the bushings and get a measurement.
The problem is the Detroit Axle steering rack.
A stock GM steering rack measures 29.8mm inner diameter at the driver's side bushing holes. This fits well with the stock GM bushings 29.9mm outer diameter and Prothane's bushings (same).
The Detroit Axle steering rack measures 31.8mm. That's a problem. Ballpark, there's 4mm of slop from side to side when you reverse directions with the steering wheel, which translates to a HUGE felt "dead zone".
I'm calling Detroit Axle today. If they can't get me a set of bushings I've got a new lawn ornament, or maybe their owner's car gets a new hood ornament... they're in Ferndale, Michigan - not quite so far from me.
Not happy. Not happy at all.
Old Jul 22, 2020 | 02:04 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Damn...that sounds frustrating!
Old Jul 22, 2020 | 03:26 PM
PacerX's Avatar
PacerX
Well, on the bright side...
I'm now an expert at removing the steering rack!
EDIT: Detroit Axle is sending me new bushings. But fair warning to all: if you use Detroit Axle, polyurethane bushings are a no-go... unless you machine your own... which is a thought that just occurred to me... Hmmmm... Aluminum steering rack bushings...
Old Jul 22, 2020 | 08:05 PM
drcook's Avatar
drcook
Are their bushings oversized ? Did they admit that ?
Old Jul 22, 2020 | 09:50 PM
PacerX's Avatar
PacerX
There wasn't any argument. I have pics of the measurement on both racks with a digital caliper showing the dimensions.
Old Jul 22, 2020 | 11:15 PM
ChumpVette's Avatar
ChumpVette
Can you post the pictures?
Old Jul 23, 2020 | 09:33 AM
PacerX's Avatar
PacerX
Sure thing. Will do so tonight.
Old Jul 23, 2020 | 09:34 AM
drcook's Avatar
drcook
I meant did they clarify that their bushings are larger than stock not that there was a problem. Knowing that they are using housings that differ than stock will benefit other folks.
You can't argue with measurements.
To Darnedest steering problem - rack moving
Old Jul 23, 2020 | 03:21 PM
MatthewMiller's Avatar
MatthewMiller
If they are sending you rubber bushings and you would prefer poly or harder, then at least one other option might be a reduction sleeve made of metal that would fit snugly in the holes for the rack, and then the Prothane bushings could fit inside the sleeves. But if you have access to a lathe, then you could machine your own either from aluminum or Delrin. I'm told that Delrin is a lot easier to machine than polyurethane because it's harder. Keep us updated - I'm sorry you have this problem (very frustrating because it's such a stupid issue for Detroit to have caused), but it's interesting to read about.
Old Jul 23, 2020 | 09:26 PM
PacerX's Avatar
PacerX
Here we go:
GM Rack:
Detroit Axle Rack:
GM Bushing:
Prothane Bushing:
My fearless assistants... if they only had thumbs...
Old Jul 24, 2020 | 12:30 AM
ChumpVette's Avatar
ChumpVette
Are they making their own castings? Or are they hogging out the mount to clean it up? Just seriously bad.
