Catalytic Converters Issue
Old Aug 6, 2020 | 09:02 PM
bbwool42's Avatar
bbwool42
Default Catalytic Converters Issue
My car is making unusual sounds and the mechanic I use says my catalytic converter has gone bad. Will this do harm to my motor if not replaced? How complicated is this to replace? Thanks, this forum has helped me a lot over the years! Thanks for any response. R Woolley
Old Aug 6, 2020 | 11:42 PM
jv9999's Avatar
jv9999
A bad CC can damage an engine if it's clogged. It's generally a PITA as are most exhaust parts. Take it to an exhaust shop for an estimate unless you're comfortable working on exhaust systems.
Old Aug 7, 2020 | 12:10 AM
vyper202's Avatar
vyper202
My 87 had 2 cats in the Y pipe coming off the manifolds and one mid way back in the exhaust line.... which one is bad? If its the single mid way in your exhaust, take it to a exhaust shop and have it replaced with a hi flow cat. I did mine and had the 2 in the front Y pipe removed, sounds much better and got rid of the 33 year old cats....
Old Aug 7, 2020 | 02:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette?
If it has the three cats, have the front Y replaced with a cat-less unit and the main cat replaced with a hi-flow unit for a nice HP gain.
I used a Random Tec cat on my prior '88 with great results.
Old Aug 7, 2020 | 06:27 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Any muffler will check you cats at no charge, if they find them bad ask for estimate, and ask if I bring you set how much.
Then go to E-bay, and see what they have in OEM which would be lot cheaper then muffler will charge you, and they would buy aftermarket, which sometimes aren't the best choice.
Old Aug 7, 2020 | 06:48 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Generally with bad cats you get a low hot exhaust low and low power or lack of RPMs.
Old Aug 7, 2020 | 08:42 PM
PacerX's Avatar
PacerX
Lose the cats.
Old Aug 10, 2020 | 11:13 PM
mtwoolford's Avatar
mtwoolford
Originally Posted by PacerX
Lose the cats.
You sir do not live in California.
Old Aug 10, 2020 | 11:17 PM
mtwoolford's Avatar
mtwoolford
Go online and look for "direct replacement" or "direct fit", assuming your cats are oem, the old ones should unbolt and the new ones bolt right back in in their place. The costs arise when trying to use an "universal" style cat; these will require pipe fabrication and welding.
Old Aug 12, 2020 | 04:10 PM
PacerX's Avatar
PacerX
Thank God.
To Catalytic Converters Issue
