Another jacking question.
Old Dec 2, 2002 | 10:53 AM
HTRK-1's Avatar
HTRK-1
Default Another jacking question.
Hey guys,
I ordered one of those jack a vette inserts to jack up the rear of my vette. One of the guys here asked if it was ok to support the rear of the car on such a small surface area of the pumpkin. Is it ok to use this? Is the Danna 44 an aluminum housing or cast iron? Thanks in advance. :cheers:
[Modified by HTRK-1, 3:54 PM 12/2/2002]
Old Dec 2, 2002 | 10:58 AM
Greg Johnson's Avatar
Greg Johnson
Default Re: Another jacking question. (HTRK-1)
It's cast aluminum. I have a jacking insert. I never had any trouble with cracking the casting. Once you get it up high enough, you want to place jackstands in the recommended places.
Greg :D
Old Dec 2, 2002 | 11:27 AM
HTRK-1's Avatar
HTRK-1
Default Re: Another jacking question. (Greg Johnson)
Thanks Greg,
Do you have the insert from Corvette central. It appears to have plastic or rubber on top, is this correct? It's a little pricey at $50, but it will definately be worth it. I cringe everytime I have to jack up the rear of the car by using GM's "jacking points". :cheers:
Old Dec 2, 2002 | 11:49 AM
Greg Johnson
I cringe, too. I have been planning on making some pads out of old tires to place between the frame and the jackstands to minimize damage from the stands. I thought I would cut pieces out of the tires and attach them to 2 x 4's and cut out holes on the bottom for the jack stands.
Another method that was brought up by Mr. Mojo is to use a four by four about 3 feet long and place it between the spare tire carrier and the fllor jack. I have done this and it works really good and you don't have to crawl under to place your Corvette Central insert.
Greg
Old Dec 2, 2002 | 05:29 PM
c4md's Avatar
c4md
I bought an adapter from the Gadget Man. Works great and is cheaper than the others. see: http://www.corvetteactioncenter.com/...9cc73ddba8f3be
To Another jacking question.
