New c4 owner
Old Sep 24, 2020 | 04:46 PM
Teacher27's Avatar
Teacher27
4th Gear
Default New c4 owner
Just purchased my first c4! I’ve been looking for a weekend sports car for about two years . Decided on a c4 because it filled all my requirements! Performance, Affordability, looks, parts availability and just plain fun to drive!
I purchased a well cared for 1992 automatic coupe with 28,000 miles. Clean car fax and Lots of paperwork. routine maintenance was performed. New water pump was installed along with a set of new tires at 22,000 miles. 2012 . Everything works as it should, drives straight no fluid residue on ground or on engine.
Looking for some advice as to fluid changing and maybe some things I should be looking at before I take a weekend trip?
Old Sep 24, 2020 | 06:24 PM
ls777z's Avatar
ls777z
I would check out belts, hoses, and even tires for cracks. Nothing ruins the new toy experience than seeing it getting towed...
Old Sep 24, 2020 | 06:36 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Enjoy your new ride!
Old Sep 24, 2020 | 08:15 PM
Teacher27's Avatar
Teacher27
4th Gear
Default My 1992 corvette
[img]blob:https://www.corvetteforum.com/3b4e1190-5b48-4155-956b-c01a63c7b79a[/img][img]blob:https://www.corvetteforum.com/a5109fc3-5c81-4f36-b995-947ce4a8ffb1[/img][img]blob:https://www.corvetteforum.com/41f94c09-e1c8-44d6-9fec-8b7a25dc64db[/img]
Old Sep 24, 2020 | 09:00 PM
darrensls1's Avatar
darrensls1
If 2012 was the year those tires were made then you should replace them. I bought my 95 Corvette with what I thought was good tires (lots of tread left). Then I noticed the car shakes badly anytime I was doing 50-63 MPH. I looked at the tires close and saw the front were 8 years old and the back ones were 10 years old. I replaced all four tires and the shaking went away. The guys at discount tires told me that the rubber itself is only good for 5-6 years. After that you should replace the tires or risk bad handling or even a blow out.
Grats on the car and welcome to the Corvette family!
Old Sep 24, 2020 | 10:51 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Congratulation, and yes - you must post some pics
Old Sep 25, 2020 | 07:03 AM
JungleCat's Avatar
JungleCat
Congrats and welcome!
Old Sep 25, 2020 | 08:09 AM
Teacher27's Avatar
Teacher27
4th Gear
Default Pictures of my C4
Old Sep 25, 2020 | 09:05 AM
pedricd's Avatar
pedricd
Congrats, that looks super clean!
I agree with the others on the tires... you are right at the EOL of them...they may look fine but the rubber gets hard and thus slippery with a torquey rear wheel drive car.
Do what I and others have done, go down one tire size (no perf or other negative impact) and there are plenty of tires/brands available. I got Riken Raptors (Michelin off brand)...they were $400 *total* for all four plus install/disposal, they are awesome (at least they fit my needs)
In regards to other maintenance, you can check the post on my car from a few months ago, I had a laundry list of things to dive through.
https://www.corvetteforum.com/forums...re-begins.html
I'd concentrate on oil, coolant flush and make sure the brakes are solid/flush if necessary.
Old Sep 25, 2020 | 09:14 AM
TXGS507's Avatar
TXGS507
Very nice example of a pristine C4... Welcome...
Old Sep 25, 2020 | 10:22 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
Beautiful car!
Congrats!
Old Sep 25, 2020 | 01:48 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Now your showing a truly beautiful Corvette, and before Winter hits, time to go on rides and check out the colors of the leaves, before you start raking them.
Old Sep 25, 2020 | 08:20 PM
MRANT212's Avatar
MRANT212
Nice C4!! Welcome to the insanity and many happy sMiles!!
Old Sep 25, 2020 | 08:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Welcome to the Forum and congrats on your sweet C4. Looks like an MN6??
You might change oil & filter, check coolant, chassis lube, tire inflation, lights all work.
Indeed, enjoy the Fall season with your new toy.
Old Sep 25, 2020 | 08:40 PM
Kincer's Avatar
Kincer
That is super clean looking C4! Congrats on your new ride!
Old Sep 26, 2020 | 09:18 AM
FASTAZU's Avatar
FASTAZU
2015 C4 of the Year Finalist
St. Jude Donor '16
Grats.... Love the colors.
To New c4 owner
