'92 CCM Code 72 (Driving me nuts)
The Service Bulletin that applies to this is: 93-68-9A. The bulletin says to add a 1K ohm, 1/2 watt resistor to two car harness wires and then connect those to a 12 volt ignition switched source. When you look at the diagram that comes with the bulletin, it shows that the connections are to be made to a purple-white and gray-black wire to a 12 volt switched source. The diagram also shows the wire colors changing to orange and white-red wires. Apparently, the stock Bose radio has wires and plugs coming out of it, and those wire colors change where they connect to the car harness plugs. Car harness side wires that you need are purple-white and gray-black. The radio side wires are orange and white-red, so forget those colors. Confusing if you don't know that the radio itself has wires and plugs coming from it because the car side plugs also have an orange and a red-white wire too (see picture). The car harness has two plugs that connected to the Bose radio. One has eight wires, the other has six. You need the six wire connector with an orange wire, a purple-white striped wire, two gray-black wires, a green-white wire, and a light blue wire. The wires you need to connect the resistors on are the purple-white wire and the gray-black wire right next to the purple-white wire. I originally had it hooked to the second gray-black wire from the purple-white wire, which is a no go. I connected a short wire (pigtail) to either end of the resistors and covered it with heat shrink. I got the resistors on Amazon for a few dollars. Next, I connected one end of one resistor wire to the purple-white wire tap and the other end of that resistor wire to the 12 volt switched source going to the radio. The second resistor connects to the correct gray-black wire and then to the same 12 volt switched source. Make sure you have disconnected the negative lead on the battery before starting all this, or things might get expensive. Once you've made the connections, reinstall everything, and reconnect the negative lead on the battery. Check if the module 1 code (72/74) is clear and if not, clear it and verify that the stupid thing isn't flashing any more.
Sorry for the long writeup, but out of all the posts I read (over and over), I still wasn't sure which wires to use and thought the details might answer somebody else's questions. Hopefully this helps anyone with the same problem. If I can answer any questions about this, I'd be more than happy to. That flashing SYS light was driving me crazy and now it's gone.
When I saw this thread yesterday, my recollection was that it was a pur/yel wire. So I got out my FSM to confirm the wire colors, and yes it is pur/white (my recollection was wrong). I also saw the TWO gry/black wires, and going by the circuit descriptions I deduced that the correct gry/blk was in Cavity #3 which is right next to the pur/wht in Cavity 2. Because you didn't have Code 74 which is the pur/wht wire, I felt you had the "fix" correctly wired for the pur/wht. Looking at your pic, I saw that the correct gry/blk was wired, I didn't have any other ideas, so I let it ride. This morning I responded to Corvette 95's input, so his response wouldn't confuse you. And now you understand what the "fix" accomplishes. (Drives the circuit high, so the CCM can detect a change of state when it runs the diagnostic).
Pretty cool that you stuck with it and solved it on your own. Congrats.
What the "fix" does is load the circuit to 12 Volts, or a "high" state. The Code 72 diagnostic pulls the LED circuit to low, then high, then low, then stops. If it doesn't see the state change from high to low to high, it sets the code. The 12 miliamps of 12V current can easily be sinked to ground by the CCM, pulling the circuit low.
The OP has installed and wired the fix correctly. (He took down his pictures, but he had tapped the correct wires at the radio connector). There are some other things that can be checked that may be clues as to why 72 is still setting. One thing I had never paid attention to in the 72 diagnostic is that it will only run and set when the dimmer request is not 0% or 100% dim. So try leaving the dimmer wheel at full brightness and see if the code stops setting.
But he has the resistor wired correctly. As long as it IS getting 12V with the key = On.
