Codes: I need a little help
Old Oct 23, 2020 | 11:20 AM
Rich Thompson's Avatar
Rich Thompson
Default Codes: I need a little help
I've got a 1994 Auto, LT1 and have recently gotten the following codes: C12 (which is good, I understand), H32 EGR code and a H48 MAF code. The car runs like it's only running on 5 or 6 cylinders at idle and all mid throttle operation. When the engine is warmed up it needs to be shifted into neutral and accelerator used to keep it running. It also requires a little accelerator pressure to start after being shut down warm. When cold. it jumps to life just fine. FYI, the opti-spark was replaced in 2016 along with plug wires and ECM, and its been running fine until these codes appeared the other day. I'm wondering if disconnecting the electrical connections at the ECM and MAF to ensure the contacts are clean would be a good place to start. Thanks for any assistance you may offer.
Old Oct 23, 2020 | 11:30 AM
Rich Thompson
Update: I just tried starting it cold and it now required throttle to start and idled rough after starting - no stalling cold though. Also, the exhaust smells really rich.
Old Oct 23, 2020 | 04:22 PM
don hall's Avatar
don hall
https://tech.corvettecentral.com/201...trouble-codes/
Old Oct 23, 2020 | 04:38 PM
vader86's Avatar
vader86
Fix the MAF code, ignore the EGR code for this.
Old Oct 24, 2020 | 10:48 AM
Rich Thompson
What is the best way to deal with the H48 MAF code? Is it as simple as purchasing a new MAF sensor from a parts store and replacing it, or is other diagnosis required?
Old Oct 24, 2020 | 09:11 PM
93Rubie's Avatar
93Rubie
Because the car has a back up mode. Unplug the MAF, with it off, start car and see if it runs better. If it does, could be the MAF. If it is the same, it isn't the MAF.
Old Oct 26, 2020 | 08:09 AM
Rich Thompson
It runs just as bad with the MAF plugged in or unplugged.
Old Oct 26, 2020 | 08:22 AM
fake's Avatar
fake
In the open loop it runs fine when first starting NO! When car is warm closed loop runs poor! Try the opti look for water from water pump which mounts over opti if so it is the opti A lot of items to consider do you have history on car? One owner? What has been replaced? Have you looked for simple things like some item loose or disconnected under hood spark plug, vacumn, line dirty air filter which can mud up pintle for air flow. Who was last under hood or under car? How about your 02 sensors are they connected? Do you have the Helmes two part for 94 Corvette manual? If not get it if you are keeping car.
Old Oct 26, 2020 | 09:15 AM
Rich Thompson
Didn't see an evidence of coolant leaking. Not a 1 owner car. No real history except that the opti and ECM were replaced in 2016. I have the bill that came with the car. Nobody has been under the hood or under the car since I got it. I've looked for disconnected/cracked vac lines and have found none so far. Air filter is clean. Haven't checked the O2 sensors but I doubt that they just fall off. The car has been running fine until recently. Don't have the manual mentioned and the jury is still out as to whether or not I plan to keep this car long term.
Old Oct 26, 2020 | 12:45 PM
vader86's Avatar
vader86
If you have the factory shop manual from Helminc.com, it'll have the specific procedure to help you not throw money at the car.
Best money you can spend if you want to work on the car yourself is the Helm manual.
Old Oct 26, 2020 | 02:13 PM
KurtK's Avatar
KurtK
Or go to Rockauto, look up your car, look in Literature, The should be a Dave Graham CD version of the FSM for $21.00
You may be able to find a used Helm manual in the C$ subsection for parts. I have both, the actual paper manual is a little easier to use when wrenching on the car.
Old Oct 29, 2020 | 10:39 PM
Nomake Wan's Avatar
Nomake Wan
This. It's worth every single penny.
And just to be sure, OP, which module were those codes listed under? The dash lists codes for the CCM first (Module 1), then the PCM (Module 4), then the EBTCM (Module 9). Just listing a code here doesn't guarantee that it's actually the right one, as the same number can mean a completely different thing for a different module. So just to be totally clear, please do list what codes come up under which modules.
Old Oct 31, 2020 | 08:25 PM
Rich Thompson
The codes shared were from module 4.
To Codes: I need a little help
