Wheels???
Old Oct 29, 2020 | 02:18 PM
84rocks's Avatar
84rocks
2nd Gear
Default Wheels???
Looks great from 20 feet away! Can someone tell me what wheels we have on our beautiful car? We've only had it a couple of weeks and we are doing the research on the car and would appreciate any help you can give!
Old Oct 29, 2020 | 03:19 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome moved you here to reach the right people. Intros are just for that. Good luck on getting your info
jehuds10's Avatar
jehuds10
Welcome to the forum!
Old Oct 29, 2020 | 03:47 PM
81c3's Avatar
81c3
Theyre stock salad shooters off an 89
Old Oct 29, 2020 | 04:02 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Also, the Z51/Z52 versions of the 1988 Corvette used the same design. Whether for '88 or '89, they are 17x9.5"; +56mm offset. Stock tires with these wheels were 275/40ZR-17.
And, this wheel in white was used on the 1988 35th Anniversary Corvette.
Old Oct 29, 2020 | 04:03 PM
84rocks's Avatar
84rocks
2nd Gear
Thanks! Super excited to be a part of the community!
Old Oct 29, 2020 | 04:23 PM
WVZR-1's Avatar
WVZR-1
Your 'user ID' hints likely an '84 .... If that's true and I don't see any CHMSL... so the wheels are likely mounted using 'spacers/adapters'. I'd think it wise to confirm which and make sure it was done well. Left side are mounted in the correct 'rotation'. Check the rights! What year is it!! VIN?
Where are you located in the 'Wild & Wonderful'?
Old Oct 30, 2020 | 05:34 PM
NOMOREWORK's Avatar
NOMOREWORK
St. Jude Donor '13-'14-'15
Had those wheels on my 89 when I bought it.
Old Oct 30, 2020 | 05:39 PM
InfomanSS's Avatar
InfomanSS
Looking sharp! Welcome to the community.
Old Oct 30, 2020 | 05:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Those are called cuisinarts, some call them salad shooters
Old Oct 31, 2020 | 12:54 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Originally Posted by cv67
Those are called cuisinarts...
^^^This^^^
To Wheels???
