LT1 vs LT4
Old Nov 4, 2020 | 12:21 PM
BLUDICE's Avatar
BLUDICE
Default LT1 vs LT4
So are there any additional concerns I should be aware of with the LT4 - I’ve owned a LT1 so I know about it.
Old Nov 4, 2020 | 12:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nope. LT4 was a high water mark, for the era.
Old Nov 4, 2020 | 02:21 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
None..... The LT4 is an LT1 on drugs
Old Nov 4, 2020 | 02:45 PM
MatthewMiller's Avatar
MatthewMiller
If you liked the LT1, you'll love the LT4. And in fact it has one less thing to worry about than the LT1: it has no EGR system because the extra cam overlap made it unnecessary.
This is not specific to the LT4, but all 1996 C4s (LT1 and LT4 alike) have a fully enabled OBD2 system. If you plan to do mods and then recalibrate/reflash the PCM, you need different and more expensive software for any 96. If you're keeping it stock, that's not a problem. And depending on the emissions inspection laws where you live, you may be required to have a 96 emissions tested whereas earlier non-OBD2 cars are not required. That's a requirement in the county where I live, but those rules are all over the map around the country. Anyway, if you've ever owned a 96 LT1 car, you've had the same system and emissions requirements.
Old Nov 4, 2020 | 02:55 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
The computer on an LT4 will handle a LT4 Hot Cam without making any changes. So you can get a bit with just a cam change.
Old Nov 4, 2020 | 05:52 PM
93 ragtop's Avatar
93 ragtop
Actually, you can get quite a bit with a hot cam and long tube headers. On a engine dyno, they have been documented at 429hp.
Old Nov 4, 2020 | 06:33 PM
drcook's Avatar
drcook
What I meant was a person can get a bit by putting in a Hot Cam and NOT having to do a tune. The computer will handle it. Once you go to headers, I am not so sure if it has the brains to accomodate them.
To LT1 vs LT4
