Help. I'm tired.
Popular Reply
And, for reference sake, HEAT (i.e., "thermal failure") is generally a symptom of electrical failures. FUEL-AIR-SPARK: Which is changing as it reaches the 195º+ region? I'd want to see what an OBD-1 scanner or Tech-1 showed what was happening at "cutoff" temperature. For example, injectors susceptible to ethanol mixed fuels typically do not show their colors until AFTER reaching operating temperature. The resistance values (again AFTER warmed up) should all be within ± 1Ω (12ish or 14ish, depending on the injectors installed). Injectors from 93 on were alcohol tolerant, but if yours are pre-93s and you run or ever ran ethanol blended fuel, chances are they need to be swapped out for new (NEW - not [so called] "rebuilt") injectors.
too. When the symptom occurs, does the car have spark, still? You mentioned not being a mechanic, so I won’t tell you now is the time to start learning but compile the information provided here by other posters to your topic and create a list from that to provide to a qualified mechanic to review the troubleshooting.
Good luck.
As for OP's comment about the oil pressure switch, just to be crystal clear, this switch does not and cannot cut off your engine unless you have completely bypassed the CCM, or the CCM has failed. The CCM is what controls your fuel pump relay. If the CCM fails, has been bypassed, or has been commanded not to run the fuel pump relay, it can be overridden by the oil pressure switch signal. However, if the CCM is operating normally, then the oil pressure switch has zero authority over the fuel pump relay.
