Heater not, errm..., heating.
Old Dec 6, 2002 | 02:26 AM
November Soul's Avatar
November Soul
Default Heater not, errm..., heating.
My heater has stopped working (actually I cant remember last time I wanted to make it warmer in there), are there any common issues that are easy fixes, or do I need to go through a complete diagnosis.
Ta!
Old Dec 6, 2002 | 12:39 PM
gh86E's Avatar
gh86E
Default Re: Heater not, errm..., heating. (November Soul)
Run car enough to get engine warm. No heat? ok, open the hood.
On the passenger side, near the outside edge of the firewall, you'll
seem 2 tubes going through the firewall. One of them has a vacumn-
activated valve on it. Push on the lever on the top - get the valve to
move 90 degrees. Wait a minute, then check if you have heat inside
now. If you do, that dual tube/valve assembly has to be changed.
This failed on both my '85 and '86, and is a very common problem.
Didn't replace it myself, but isn't hard. If you want to buy the part
and replace it yourself, and don't already know about Jeff Kopp,
email me - I'll tell you how to get it at less cost than local Chevy dealer.
Old Dec 8, 2002 | 03:11 AM
November Soul
Default Re: Heater not, errm..., heating. (gh86E)
Thanks very much, I'll check this out first thing tomorrow. Sounds about right, my heater used to work. :cheers: for the help :chevy
Old Dec 8, 2002 | 07:37 AM
Casper's Avatar
Casper
It could just be your thermastat. Is the heater just blowing cold air or not blowing at all?
Old Dec 10, 2002 | 04:48 AM
beachcat's Avatar
beachcat
Good troubleshooting idea! I need to check mine, it may get cold here someday.
To Heater not, errm..., heating.
