solid targa repair
Old Dec 2, 2020 | 01:23 PM
mcm95403's Avatar
mcm95403
Default solid targa repair
I picked up a used solid/fiberglass targa top for my 91 but the shell is separated from the frame along the front edge - the fiberglass is no longer bonded to the frame. Is there an "easy" fix where I can bond it back in place and if so what is the correct glue to use? If I need to pull out the liner I could do that was well, I've just never had to pull one of these apart before. I'd rather fix it myself if possible rather than sending it out for a complete rebuild.
Old Dec 2, 2020 | 02:40 PM
FAUEE's Avatar
FAUEE
Fully separate it and use betaseal to glue it on. Hot Rod Roy has a great write up on it.
I redid mine a few years ago and it's held up great.
Old Dec 2, 2020 | 11:01 PM
mcm95403's Avatar
mcm95403
Thanks, I found his post!
To solid targa repair
