What can the chip control?
Old Dec 7, 2002 | 02:15 PM
Lord Odin's Avatar
Lord Odin
Default What can the chip control?
I already know that we can stick with our originals, buy premade, have them custom made, or program them ourselves, but what all can the chip control exactly?
Old Dec 7, 2002 | 02:24 PM
bogus's Avatar
bogus
Default Re: What can the chip control? (Lord Odin)
timing, fuel delivery, air/fuel mixture, engine temp...
pretty neato, eh?
all the engine computers to about the same thing, the question is how many inputs (ie, how smart is it and how much info does it have to work with) and how fast it does it. basically, the computers speed will determine if we are dealing with a course calculations or fine calculations.
there are seperate computers that share some data for display and such, and then totally seperate systems, for like climate control and ABS/traction control.
Old Dec 7, 2002 | 02:26 PM
Lord Odin's Avatar
Lord Odin
Default Re: What can the chip control? (bogus)
Ok, so how much can a computer control a car's acceleration? A friend of mine thinks that it has very little contol over the car.
Old Dec 7, 2002 | 03:33 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
While not exactly a chip. ECS took my buddies supercharged C5 and did LS1 edit on it. He got an additional 50 HP out of it from tuning. Most of it came from leaning it out. His car was super rich.
Old Dec 7, 2002 | 05:45 PM
vader86's Avatar
vader86
Well if you optimize the A/F ratio for maximum torque output at low rpms, you could improve acceleration, might not be a big difference from stock though.
Old Dec 7, 2002 | 08:45 PM
LaVidaLoca's Avatar
LaVidaLoca
Let's see; the computer controls the amount and timing of the fuel and the timing of the spark. That about covers control of the engine doesn't it? It is not at all like driving with a carb where you open a valve manually and control the gas flow. With a fuel injected Vette you press down on the gas and the computer looks at all the other inputs and controls how the engine performs.
It is actually pretty cool for a car with this much performance to get such good gas milage. The engine has a throttle position sensor feeding the computer so it can give you quick power or better milage depending on how much throttle you give it.
Old Dec 7, 2002 | 08:57 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
The big question is what can't the ECM control????
:eek:
Old Dec 8, 2002 | 02:31 AM
GDP's Avatar
GDP
What everyone else said, PLUS shift points on an auto, the rev limiter/top speed, fan on/off temps, knock retard, detonation, speedometer, and tachometer.
[Modified by GDP, 1:32 AM 12/8/2002]
Old Dec 8, 2002 | 03:39 PM
Nathan Plemons's Avatar
Nathan Plemons
Your friend is partially right in that it can't control acceleration directly. Acceleration is dependant on a lot of things, mainly weight, traction and power. Obviously you can't change weight or traction in the computer so you can only deal with power. There is no simple power control in the computer though and it has to be dialed in with very careful monitoring of operating conditions and making small changes. You then analyze those changes and tweak it some more.
You can do this with volumetric efficiency, power enrichment, spark advance, etc, etc. There is a LOT of stuff that the computer looks at and makes it's calculations. Then on the auto you can affect acceleration a little bit by changing the shift points and such as it was mentioned above. The 92 doesn't even have some of the things that the newer computers do but it still allows you to control how the engine responds to it's inputs.
So technically friend is wrong, you can control acceleration in the computer, you can speed it up or you can make it run like complete poopie, but it's a lot more complicated than just punching in an acceleration constant. :cheers:
[Modified by Nathan Plemons, 2:41 PM 12/8/2002]
Old Dec 10, 2002 | 04:30 AM
93 ragtop's Avatar
93 ragtop
Default Re: What can the chip control? (GDP)
According to Fastchips, they can change the TC lock up, but there is no control on the auto shift points. (93 and earlier) Also they can enhance Traction Control, timing, fuel curves etc.
Old Dec 10, 2002 | 07:51 AM
Jimbo93's Avatar
Jimbo93
I have a 93 Vette with the Ed Wright Stage 2 Fastchip with 160 degree thermo
(which is a must for the stage 2 chip). What it does for me is:
1. Eliminate the skip shift
2. Turn cooling fans on at 180 degrees F and off at 170
3. Raise rev limiter to 6200 RPM without spark retardation
(stock chip limits revs below 5800 and retards spark)
4. Slightly lean out fuel/air mixture
Old Dec 10, 2002 | 01:03 PM
Lord Odin's Avatar
Lord Odin
Default Re: What can the chip control? (Jim Holbrook)
If the chip in the 93 and earlier can't be controlled as much as the 94+ cars, couldn't the computer just be replaced by a different one? AKA, replace it with a laptop or swap the computers for a 94+ comp? I would think the laptop or something similar would be easier to do though.
Old Dec 10, 2002 | 02:52 PM
bogus's Avatar
bogus
thats a case where there is more than just a chip in difference.
the later computers are faster, yes, but they have more than just a chip. the chip stores information specific to the engine... the processor makes some of the decisions... the chip holds the data and the programming.
if the chip is not compatiable with where it is being plugged, it won't work.
thats why the earlier Crossfire cars are upgrading to later pickup ECMs... faster, with the same inputs.
a real easy upgrade.
Old Dec 11, 2002 | 08:08 AM
93 ragtop's Avatar
93 ragtop
There are a lot of differences between 93 and earlier and 94 and up. Some of them are the older LT1 use a speed denseaty system, the 94 and up use mass air flow. The auto transmission is mech. controlled on the older and newer ones are electronic. I dont believe the conversion would be worth it. If you really want the pcm controlled car instead of a ecm controlled car, IMO it would be easier to trade for a newer vette.
To What can the chip control?
