Paging Lord Odin
Old Dec 7, 2002 | 03:53 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Paging Lord Odin
Here's a pic shwing the difference between the two ASR/TCS units(called an EBTCM)
The Bosch 2U is in the '92-94 and the Bosch 5 is in the '95-'96 except ZR1 which still used the 2U.
The difference between the two is that the 2U has a 3 channel Hydraulic Unit Outlet Pipe with a front/rear split(the two rear are controlled by the same valve solenoid)
The Bosch 5 has a four channel with a front/rear split.
There are a ton more diagrams and stuff, too many to scan.
I got this info from a GM Tech manual, there are two phone #'s, maybe you can order one. I got mine on ebay for $10.
1-800-393-4831
1-800-468-6657
Old Dec 7, 2002 | 03:54 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Paging Lord Odin (Mr Mojo)
Click on the pics to enlarge.
Old Dec 7, 2002 | 04:27 PM
Lord Odin's Avatar
Lord Odin
Dude, you're AWESOME! Those setups look kinda complex. You think its possible to do the conversion or even worth the effort? If it is, I'll do it because the ASR on my car just feels primitive in comparison to my dad's 98.
To Paging Lord Odin
