Courtesy light problem
Old Dec 20, 2020 | 07:31 PM
OzyC4's Avatar
OzyC4
Default Courtesy light problem
I seem to have a problem with my car. I've recently had the passenger side door apart to do some repairs and now that it's back together I have a problem with the door courtesy light staying on.
All the other lights go out on the timer except for the passenger door one, so I'm wondering where I've stuffed up.
Can anyone tell where I should start looking?
Up until this happened I was pretty happy because I only had 2 screws left over.
Old Dec 20, 2020 | 08:53 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
I've had to "adjust" the plunger on the door switches ... see if this post helps https://www.corvetteforum.com/forums...post1600949529
Old Dec 20, 2020 | 09:49 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
push the light and turn it off
Old Dec 21, 2020 | 04:10 AM
OzyC4's Avatar
OzyC4
I don't think that it's a problem with the door switches as all the other lights go out with the timer except for the passenger door one. It's been like this since the car was in an accident.
Old Dec 21, 2020 | 04:11 AM
OzyC4's Avatar
OzyC4
I don't know if all models are the same but my 88 doesn't seem to have any switch on the light.
Old Dec 21, 2020 | 06:07 AM
ls777z's Avatar
ls777z
The light lense is the switch, just push it as suggested. The other thing to check are the wires going to the back of the light itself. They are pretty flimsy and break rather easily. Could be one is broken and causing the light to stay on.
Old Dec 21, 2020 | 07:27 AM
Cruisinfanatic
If you look carefully at the lense, it will say push on lower corner
Old Dec 23, 2020 | 10:43 PM
OzyC4's Avatar
OzyC4
Thank you guys for pointing out something that I missed in over 2 years of ownership.
I never twigged that you could turn these lights on.....Doh!
To Courtesy light problem
