C4 driver window issue
Old Dec 24, 2020 | 08:36 PM
Nicholas Godwin's Avatar
Nicholas Godwin
5th Gear
Default C4 driver window issue
I have a 84 corvette and the window closes about half an inch from the top. Wasnt sure if this was a motor or regulator issue. I think its a regulator issue, but i just want clarification.
Some things that might help is it moves significantly slower going up than down. The passenger side moves much faster which could be because it was upgraded. It moves up fine it stops half inch below where it should.
Old Dec 25, 2020 | 11:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might remove the door panel and access panel to lube the mechanisms and see if the stops need adjustment.
Old Dec 25, 2020 | 01:05 PM
Nicholas Godwin
5th Gear
i will do that and get back with you. Thank you
To C4 driver window issue
