Catalytic converter
Old Feb 25, 2021 | 05:56 PM
ZAKS VETTE's Avatar
ZAKS VETTE
8th Gear
Default Catalytic converter
Hi, i think my cats are clogged it just wont go with out bogging down to 10 MPH.
Q. Can i just remove them and replace with down tubes and add new o2 sensors?
I just moved and I dont have my manuals, 92 conv lt1 do I have OHV or DOHC? Sorry just don't remember...
Old Feb 25, 2021 | 06:07 PM
Fiberbundle's Avatar
Fiberbundle
Do you have to pass emissions testing? If you don’t, just hollow them out and be on your way.
But are you sure it is the cats causing your issues. Have you pulled any codes to see if it is anything else?
And LT1 is OHV.
Old Feb 25, 2021 | 07:19 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Why don't you check there temperature, OK stop laughing, when there clogged there hot, above normal.
I had them replaced, and replaced 02 sensor!
Old Feb 25, 2021 | 11:08 PM
aklim's Avatar
aklim
Isn't a downpipe for turbo systems? What exactly are you trying to do and what are these down tubes? Which cat is clogged? Does your 92 have a cat and 2 cats before that? How did you determine which one was clogged?
If you want to prove something, can you disconnect the exhaust system from the end of the manifold and see if it will go past 10 mph before doing something irreversible? It will make the car noise which appeals to the rice boys but might not be so nice in the cabin.
Old Feb 27, 2021 | 04:30 PM
ZAKS VETTE's Avatar
ZAKS VETTE
8th Gear
Thank's can't pull codes no ECM. Going to get it fixed. No emissions testing so I'll just hollow them out.
Old Feb 27, 2021 | 04:32 PM
ZAKS VETTE's Avatar
ZAKS VETTE
8th Gear
Thank's yes I could check temp great...
Old Feb 27, 2021 | 04:41 PM
aklim's Avatar
aklim
How do you have no ECM? Is this carbed or what?
Old Feb 27, 2021 | 06:52 PM
Jackson84's Avatar
Jackson84
If you can, I would take a sawzall and remove them from the equation completely, if you dont need emissions, that is. Im sure there is a post about relocating o2 sensors.
Old Mar 1, 2021 | 11:18 AM
ZAKS VETTE's Avatar
ZAKS VETTE
8th Gear
no com to ECM dash says SYS and security and brakes flash
Old Mar 4, 2021 | 07:32 PM
SJW's Avatar
SJW
Before I did anything else, I'd put a vacuum gauge on that engine, tape it to the windshield, and see what manifold vacuum does when it bogs down. Certainly before I reached for a sawzall or any wrenches.
Live well,
SJW
To Catalytic converter
