Your link went to Dex VI and I'm sure that's what you intended BUT your comment 'backwards compatible' ain't accepted as 'gospel' by many or most! Makes you happy then it's fine for @kael but maybe NOT for most. Ain't for me and I don't care about anyone but me!!!
What is it you and your party recommends? Dextron 3 is no longer produced.
See post #16 - sometimes you just need to 'read'.
OP - how many miles have you and Father put on this car since 'purchase' - everyone wants to mention 'after purchase' Father says it 'slipped' you say NOT - 2 months?
Actually GM has advised against any vehicle having the trans fluid changed by use of a machine that transfers the fluid by use of a circulation pump . I follow this method for all my vehicles , drop the pan , save and measure the removed fluid , change the filter , install a drain plug in the pan and reinstall it . Then I add the same amount of fluid that was removed . The next time I feel the fluid needs changing the drain plug makes the job a snap as I repeat the process only skipping the filter change until it's needed .This process repeated on a regular basis maintains relatively fresh fluid all the time .
GM does a fluid exchange. They hook your tranny lines at the radiator to a machine, add fresh tranny fluid to the machine. Then they run your car and the tranny pump pushes the old fluid into the machine and that pushes new fluid back into your tranny. No solvents are involved, it is just a complete fluid exchange. Many folks confuse this with a flush.
Do it yourself. When you get a used car the mantra is "if it flows, it goes." It is super easy to change the fluid on these cars. Here's the video I used:
Transyn is a BP/Castrol brand, right? TES-295 is a spec, right? Most of the vendors do say it works just as well with Dextron VI. What spec are you seeing for a 700R4 that says it needs TES-295 or an Allison spec fluid?
Yes you actually are confused and bordering on maybe much worse! But you've been there for 'years'! 295 spec has long been considered an outstanding replacement for any DEXIII spec that ain't been available for a very long time. 295 spec is now done by many more than just the TranSynd product that I and others have used for years.
Read!!! LEARN!!
Perhaps so but I don't know if you are really qualified to make a diagnosis over the internet, are you?
Relevance? It doesn't answer the question, assuming you do know the answer. We know it is an approved spec for Allison. I don't know why it is so necessary for a 700R4 over Dextron VI. One I can get easily at any auto parts store. The other, not so easy. You stated you don't think Dextron VI is NOT the right replacement for Dextron III in spite of the vendors saying so. You don't even explain why. What are your qualifications that we need to swallow your words wholesale?
OTOH, maybe I should since you don't seem to know the answer.
There's much more that if a person would like to 'argue/discuss' the '87 in particular.
What are you going to use for fluid? Since there's no readily available Dexron III available I'd be concerned with maybe fluid. Were it me I'd use TransSynd TES 295. Expensive but pretty readily available for anything that still has a spec for Dexron III. It's what I've used for my 4T65e
OP - warm the car drive a few miles - suction whatever can be recovered from the fill tube and check the condition of it! Use what you see or have it analyzed by those that might have a professional opinion as to how to proceed. I'd think most would suggest drain, filter and fill. Start twisting 35 year old flare nuts and think about where you might end up!
The spec for the factory auto transmission in my 89 is "Dexron II".
What's the difference between TransSynd TES 295 and AC Delco Dexron VI that's mineral based?
I'm going to be changing the filter in my transmission and so was looking at using AC Delco Dexron VI that is mineral based.
Next week 6:14-21 I receive a vehicle I purchased through eBay the car has 23,000 miles on it it's a 1996 c4 automatic I believe the cars have been a garage queen most of it's life. First thing I was advised to do is change out all the fluids. I've had high mileage vehicles before and they always point back to don't change the fluid cuz you're going to lose all the residue from the clutch plates on the automatics, & the transmission will start to slip! A penny for your thoughts about swapping out the gearbox fluid on this 23,000 mi vehicle TIA!
If it flows it goes. Yes, change it. Not for the mileage but for the age and you don't know what the previous owner might have done. As far as changing the fluid hurting the trans, I've only heard that happening on cars where a trans fluid change was severely neglected. In your case you will be fine.
Psstt, at certain times, DEXRON III didn't exist. Wasn't released until 1993. https://en.wikipedia.org/wiki/DEXRON
Did note a likely typo in wikipedia's article, will have to look. DEXRON VI (6)? When was IV (4)?
I went thru the same situation when I bought my automatic 3 years ago . Transmission fluid was brown at 64k miles.
Took it to a Corvette specialty house and was told that they wouldn't do it and I should just drive the car to the point of transmission failure. That didn't make much sense to me so I went to my friendly Chevy dealer for a second opinion. They advised against changing the fluid
The third stop was at a specialty shop run by Bob, a guy who had made his living for 35 years doing nothing but working on transmissions and here is how he explained it to me. Bob said that would be truth in cars up thru the mid 1980s but transmissions built after that were made to a much higher standard since then. I gave him the go ahead and he drained all fluid and cycled new transmission fluid thru the unit till it came out clean which also meant the torque converter. He then replaced filter, gasket and speed sensor, filled with new fluid and "voila!"--no issues no problems. There's a lot of opinions out there but best to go with experience IMO.
Yeah, a lot of people like to say our cars with with Dexron III from the factory when really most of them came with Dexron II. Something I learned recently is that there are different versions of Dexron III. With Dexron III-H being the last version.
I plan on changing my automatic transmission fluid with Amsoil ATF Signature Series. I believe that version is a thicker viscosity as they rate it for Dexron II and III. Whereas their "Fuel Efficient" version I believe is a thinner viscosity and it's rated for Dexron VI. I figured it's best to try and stick with a similar viscosity as Dexron II and III since our transmissions were built for Dexron II or III and not VI which is thinner.
