Engine Temperature.
Old Dec 11, 2002 | 05:03 PM
reddie95's Avatar
reddie95
7th Gear
Default Engine Temperature.
My 1995 coupe runs between 201 and 209 on the freeway. Is this normal? It gets up to 225 in traffic pretty quickly....
Old Dec 11, 2002 | 05:10 PM
n1kki6's Avatar
n1kki6
Default Re: Engine Temperature. (reddie95)
seems normal, thats how hot mine ran before i put in a 160 thermostat.
Old Dec 11, 2002 | 05:12 PM
Tonys96's Avatar
Tonys96
That's where my '96 runs also, there've been many posts on this topic and everyone has their opinion. I personally don't believe that GM made a mistake.
You should check that the A/C condensor or the radiator are not plugged, (they like to pick up all the junk on the road)and if it hasn't been done already, flush and change out the coolant.
:cheers:
[Modified by Tonys96, 10:12 PM 12/11/2002]
Old Dec 11, 2002 | 05:16 PM
vader86's Avatar
vader86
normal
Old Dec 11, 2002 | 05:23 PM
GDP's Avatar
GDP
It's completely normal. I've seen 240 once in heavy traffic during the summer. :eek:
I have a 160* thermostat that I'm going to install when I do my throttle body coolant bypass with a '95-'96 upper radiator hose. Should lower it quite a bit. :yesnod:
Though, now I guage it mostly by oil temps. I don't take it over 2000 RPMs until the oil temp reaches 160*.
Old Dec 11, 2002 | 06:04 PM
GS 163's Avatar
GS 163
Cruising down the highway today at about 85-90 mph, turning about 3000 rpm, temp was at 184, and fans were not running.
To Engine Temperature.
