C4 CDM Removal?
Old Mar 10, 2021 | 03:25 PM
ddischiave's Avatar
ddischiave
Default C4 CDM Removal?
As a new member I risk asking a question that has already been answered and posted. Please bear with me. I did search the forums but didn't find what I was looking for. I have a '91 Corvette Convertible and generally do all my own maintenance but I have to admit for some of the electrical issues I usually need help. The problem: the radio powers up and the antenna raises up, but out of the speakers is a loud squeal. The same is true for the CD player. So I've concluded that it is either the radio unit in the center of the dash or the CDM which in my car is under the passenger-side dash. So before I start dismantling the dash, I have two questions:
1. Could it be the CDM?
2. Can the CDM be accessed easier by removing the glove compartment?
Thank you, Dave D
Old Mar 10, 2021 | 03:45 PM
jrobin1's Avatar
jrobin1
The bose speakers in these cars are notorious for failing capacitors, resulting in a number of symptoms including no sound, static, squealing, etc. So, while it could be the CDM or the Control unit, both of which are in the dash of a 91 (i believe), it could also be speakers. These may be easier to look at first. They certainly are more easily accessed than the other items.
Old Mar 10, 2021 | 06:25 PM
ddischiave's Avatar
ddischiave
Thank you for that heads up. There are 4 powered speakers. Two in front and two behind the rear behind the seats. If only one is bad will it negate any audio coming from the other three? This audio systems to have a bunch of moving parts.
Old Mar 10, 2021 | 08:04 PM
jrobin1's Avatar
jrobin1
Not likely that 1 would make all not work, but it is not out of the question that they are all bad. The capacitors are about 30 years old.
Old Mar 10, 2021 | 09:24 PM
ddischiave's Avatar
ddischiave
Thanks for the advice. Looks like this project has gotten a little bigger. So, to pull all 4 speakers, test them and hope one of them is the culprit. If none of them are bad, I should pull the CDM. Is it possible to access the CDM by removing the glove box? Because the alternative is taking Houdini lessons to attempt to reach the CDM from underneath the dash. Yikes, I just hope I don't get stuck in there. The things we do for radio reception.
Please keep the suggestions coming ... I can use all the help I can get.
Old Mar 10, 2021 | 09:38 PM
jrobin1's Avatar
jrobin1
I have a couple of 93s, so my CDM is in the rear compartment behind the passenger seat. Much easier to get to! I just finished replacing all capacitors on my 4 amplifiers (each speaker has an amplifier). If you have a service manual, there are some diagnostic flow charts in the electrical section (search radio diagnosis if you have the CD) and find the one that says no sound out of speakers. There are several very good threads on this forum about the bose system so search that and read them. Also, on you tube there are some good videos, Mark's corvette has a 4 part series on the capacitors. There are a number of repair shops that various people on here will recommend. I have personally used Car Stereo Help and Bose Central, both located in Florida. Even if you use them, you will have to pull the offending unit/units.
Old Mar 10, 2021 | 10:03 PM
ddischiave's Avatar
ddischiave
Great advice. I have a Chiltons, but it isn't as detailed as I need but I could use a shop manual for the '91. If I understand the CDM correctly, it appears that the CDM is an amplifier that feeds an audio signal to all four speakers. However, I'd like to know what they really do. I'm hoping the speakers are ok and that I can get get the CDM repaired. I like the idea of keeping the car as original as possible. I'm jeolous of your '93s, GM got smart relocating the CDM in the back behind the rear seats. I suspect they needed the room vacated by the CDM for the passenger side air bag. I'll take your advice and check out the Bose related threads. Thanks.
Old Mar 11, 2021 | 10:14 AM
vette196's Avatar
vette196
why not get the speakers rebuilt(sounds like they need it) and see what happens. That might correct the problem, if not then go through the process of removing the CDM/radio
Old Mar 11, 2021 | 10:26 AM
ddischiave's Avatar
ddischiave
The speakers are certainly easier to access. I suspect the speaker amps have the same capacitor issue as the CDM. It seems odd to me that all four speaker amps would ll fail at the same time.
Old Mar 11, 2021 | 10:47 AM
jrobin1's Avatar
jrobin1
Dave, on my 93s there is a relay that controls the feed to the speakers. If you can find that on yours, you should check it for proper operation (mine, of course, is in the rear storage compartment). If it is bad, that would cause all 4 speaker to not work. My rear hatch on the convertible did not work and it was the relay with a corroded connector. One thing you should ask on every problem on these cars is, "Could this be the result of a bad/corroded connector or ground". You will be surprised how many times the answer is YES.
I also meant to ask if the speakers were inop when you acquired the car. If so, they may not have all failed at the same time.
Old Mar 11, 2021 | 05:02 PM
ddischiave's Avatar
ddischiave
No, I bought the car new, so everything on the car worked. So fast forward 29 years everything still worked fine. In year 30 i.e. now, when I turned on the radio the antenna went up, the radio lite up but the sound was a high-pitch squeal. The car has always been kept in my garage and covered and I rarely ever had the top up ... maybe 10 times in 30 years.
I'm thinking about disconnecting one speaker at a time and if nothing changes reconnect it and move on to the next speaker etc in hopes that it is only one speaker. If after I sequence through all four speaakers and nothing changes then I'll see if I can access the CDM from the top by removing the glove compartment. If not, then try my hand at being Houdini by trying to reach it from under the dash ... I'm hoping I don't have to remove the passenger seat.
Old Mar 11, 2021 | 08:16 PM
jrobin1's Avatar
jrobin1
That is a good approach. When I redid my capacitors recently I didn't ace the front passenger amp repair the first time and when I plugged them up, I got a real squeal out of it. I unplugged it and the other three worked fine. While you are at that connection, you should put a meter on the power and ground wires (there are 4 and 2 are the signal wires) and verify that you have power at the speaker (if not check the relay). Also, turn volume up high and put your ear real close to speaker to see if you hear anything at all.
Old Mar 11, 2021 | 08:43 PM
ddischiave's Avatar
ddischiave
Excellent suggestions. Thank you. I have a multi-meter so I'll get this process started.
Old Mar 11, 2021 | 10:53 PM
jv9999's Avatar
jv9999
The CDM/Receiver is a bit of a PITA to get to. Removing the glove box doesn't help at all. Remove the under panel and the side panel. It's stacked to the right of the relays under the cruise control module behind the main fuse panel.
Old Mar 11, 2021 | 10:57 PM
ddischiave's Avatar
ddischiave
Thanks for that advice. It will save me from removing the glove box for no good reason.
Old Mar 14, 2021 | 08:14 PM
corvette95's Avatar
corvette95
If your planning on keeping the car, get a FSM and bite the bullet and pull the CDM, if it don;t need it now, it will, and soon. Yes, there is a lot of stuff that needs to come off on the passenger dash, it can be done in under two hours, an hour if you have done it before.
Old Mar 14, 2021 | 09:52 PM
ddischiave's Avatar
ddischiave
It's probably the prudent thing to do. Thanks, I prefer to keep the car original. I suck up the pain and with some Houdini lessons I'll get it done. thanks.
To C4 CDM Removal?
