Tire Date Code
Old Mar 19, 2021 | 03:03 PM
jdcar32's Avatar
jdcar32
Default Tire Date Code
Bought a '93 coupe with Michelin Pilot Sports but I'm suspicious of their age. The dot codes are 4M 57 002X rear and 4M 4M 001X front. The last four ( circled ) digits don't jive with standard DOT date code designations. Any thoughts ?
UPDATE : I found an inside sidewall code of 5308 so it's off to the tire store ASAP. But, after searching I'm not finding much in the original sizes. Downsizng from 285/255 to 275/245 looks like my only alternative. It would be the first time I've ever bought SMALLER tires! What size/brand C4 tires have you all found and purchased ?
Like
Comment
Old Mar 19, 2021 | 03:42 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Pre 2000. Get them off asap
Old Mar 19, 2021 | 04:13 PM
ChumpVette's Avatar
ChumpVette
Like
Comment
Look at the Continental for the original sizing. Otherwise, going to a square setup is best. But you will ideally need to update the front sawbaldes to a wider rim to get the 275 to fit properly.
Old Mar 19, 2021 | 09:58 PM
Cruisinfanatic
Like
Comment
picture?
Old Mar 19, 2021 | 10:14 PM
jdcar32's Avatar
jdcar32
The driver side tires have an incomplete DOT code ( ending 002x / 001x ) where as the pass side tires have the full code ending with a valid date. Don't ask me why. Any how I'll probably go with Nitto 555's because they are affordable and one of the very few offered in the OEM size.
To Tire Date Code
