Fan controller
Old Mar 20, 2021 | 04:25 PM
jose.alvear-cl's Avatar
jose.alvear-cl
Default Fan controller
Hello friends, how are you, do you know about the fan controllers, are they a good option to activate the electro fans before? ..
Regards.
Old Mar 20, 2021 | 05:51 PM
AgentEran's Avatar
AgentEran
Regards.
what year car? Alot of people use one of these deals. Wire it into the fan relay:
Old Mar 20, 2021 | 06:32 PM
jose.alvear-cl
Hello how are you, if it is the year 1994, I am looking at options, here in the city there is a lot of traffic, before going to the highways, so I want to see if someone can program a computer, to lower the parameters. I have been told that the electro fan controllers work very well, it would be like plan B.
Greetings.
Old Mar 20, 2021 | 07:29 PM
Nomake Wan's Avatar
Nomake Wan
On a 1994 you don’t need a fan controller. You can very easily reprogram the PCM to activate the fans however you want based on vehicle speed, coolant temperature, and/or oil temperature.
Grab one of these PC cables: http://aldlcable.com/products/aldlobd2u.asp
Grab this program to read and flash the PCM: http://fbodytech.com/flashhack/#Downloads
Grab this program to make changes to the tune: https://www.tunerpro.net/downloadApp.htm
Grab this definition for the 1994-1995 Corvette to use with TunerPro: http://fbodytech.com/eex-tunerpro-definition/
And there you go. Total cost is the cable alone, and no need to splice wires or any of that nonsense.
Old Mar 20, 2021 | 08:32 PM
jose.alvear-cl
Ok, muchas gracias amigo.
Saludos.
JAZ
Old Mar 20, 2021 | 11:46 PM
Nomake Wan's Avatar
Nomake Wan
No problem! If you need any help feel free to ask, I’m more than willing to assist however I can. Good luck!
To Fan controller
