Windshield interior base seal ?
Old Apr 2, 2021 | 05:03 PM
jdcar32's Avatar
jdcar32
Default Windshield interior base seal ?
My '93 has a black foam seal of some type at the base of the windshield on the interior side. Mine looks like old foam with lots of cracking but it is still fairly soft. It lies between the base of the windshield and the dash pad. Have any of you worked on this or replaced it? Does anyone know what it's actual function is ? Thanks.
Old Apr 3, 2021 | 08:10 AM
corvette95's Avatar
corvette95
It cannot be replaced unless you take the windshield out. The material is a bulk product and can be sourced at any windshield shop. It is mostly cosmetic. If you ever need your windshield replaced, change it, otherwise, you have to live with it.
Old Apr 3, 2021 | 12:46 PM
jdcar32's Avatar
jdcar32
Thanks for that information, I was mostly just curious, always looking to increase my knowledge of my C4.
Old Feb 9, 2022 | 09:52 PM
alexallgood's Avatar
alexallgood
I have the same problem on my 95. Can I replace that strip if I take out the dashpad? Or is removing the windshield the ONLY way?
Old Feb 10, 2022 | 11:12 AM
novaks47's Avatar
novaks47
Windshield has to come out, no way to remove the strip otherwise. It's pinched between the glass and the chassis.
Old Feb 11, 2022 | 04:45 PM
hawk454's Avatar
hawk454
I replaced my windshield last year and used 3M 3/8 height 1/2 width windshield foam (I believe it is urethane foam). It is used to set the height while the 3M polyurethane (black) window seal dries. It also helps insulate wind buffeting noise at higher speeds. After the poly-stuff sets the foam is no longer holding height and normally one sided-taped. Two layers are used at the bottom, one below the VIN and on above. The poly is on the outside of both foam layers and provides the water seal.
Without the dash in place you might be able to replace the most interior layer. It does protect the VIN plate from getting dust in that cavity.
I might have some pictures at home of the area without the windshield.
Old Feb 12, 2022 | 03:58 AM
Z51JEFF's Avatar
Z51JEFF
This seal has a hard rubber channel it's attached to. There was one on eBay a awhile ago,$1000. Yes,a $1000 dollars. I've got one I bought years ago somewhere. Over time the 2 pieces separate.
Old Feb 12, 2022 | 08:32 AM
jdcar32's Avatar
jdcar32
That's great insight hawk454, thanks. I'd ( we ) would like to see some pics if you find them.
Old Feb 18, 2022 | 03:45 PM
rappini's Avatar
rappini
I use GM Silicone to preserve it until a stone cracks my windshield and I have to replace it along with that gasket.
To Windshield interior base seal ?
