Vibration/Shaking
Old Apr 19, 2021 | 10:30 AM
eric9029$'s Avatar
eric9029$
2nd Gear
Default Vibration/Shaking
Hello,
I just put on new tires(Conti Pro Sport) on my 1996 Vette. Since putting them on I have noticed quit a bit of shaking/vibration while driving over bumps. The steering column shakes. I am getting the tires rechecked (pressure/balanced) Any thoughts? Ideas?
Also would the car shake more with the targa top on and off.
Thank you,
Old Apr 19, 2021 | 10:48 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
A C4 will definitely shake more with the top off.
You're on the right track w/tire pressures and balance
Old Apr 19, 2021 | 01:17 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Something with the tires. Some balancing machines don't center the rims correctly. Make sure of that. Could be a bad tire. The wheel shouldn't shake having the top off. Granted, with the top off the car is more flexible, but the wheel shouldn't shake.
Is it at all speeds ? Get worse the faster you go ? etc
Old Apr 19, 2021 | 09:24 PM
93QuasarBlue's Avatar
93QuasarBlue
Yeah scares me about the contis. But it was happening with the 18 yo Goodyears. I put a Gopro camera in the wheel well it really works, I found the culprit. So I had the wheel straightened but they didn't fix the wobble. New set of 17" ZR rims on the way and 2 new 285/40s. I wanted to avoid wide fronts b/c they bend easily. oh well.
Old Apr 20, 2021 | 06:26 AM
Chris44m's Avatar
Chris44m
2021 C4 of the Year - Modified Finalist
Originally Posted by eric9029$
Hello,
Thank you,
As far as any shake to the car, i have a 96 convertible, I just took it for a drive down the interstate Sunday, umm, top down, about 80 mph, not so much as a wiggle, plenty of bumps on interstate 80 in Pennsylvania Yes the cars flex, but nothing shakes on my car, so I'm sure there's a suspension issue, or a rim issue or a tire issue.
Old Apr 20, 2021 | 06:32 AM
Chris44m's Avatar
Chris44m
By the way if your anywhere close to me i have four decent tires and rims for a stock 96, if you wanted to swap a set out and see if that helps?
To Vibration/Shaking
