Digital Dash Replaced
Old Apr 20, 2021 | 04:36 AM
Darrellv's Avatar
Darrellv
Navigator
Default Digital Dash Replaced
I'm working on a 92 c4 car. I bought the car and the dash was not working correctly. So I swapped out the cluster with a rebuilt one. However someone has been into the lower dash area before, maybe doing an alarm system. The meatal crush panel behind the carpet...under the steering column. Where missing to of the 4 bolts used to hold it up tight. The left side has 2 larger bolts and the right side uses to smaller bolts and in a tricky location. They are the ones that are missing. I am assuming they have been dropped fallen into tunnel area under the carpet and console area.
With all of that being said...does anyone know the size of the 4 bolts I need for that panel??? I like to put the correct ones back into the panel and hold it up tight.
Old Apr 21, 2021 | 04:33 AM
Darrellv's Avatar
Darrellv
Navigator
Any Help...from the Corvette gods ????
