Two alternator options
Old Apr 27, 2021 | 03:32 PM
vette196's Avatar
vette196
Default Two alternator options
I'm looking at replacing my alternator and came across these two choices. The only difference I can see is one is a "professional" grade and the other "Original Equipment"
Is there any other differences?
Is the O.E. one worth the extra money?
Amazon Amazon
Amazon Amazon
TIA
Old Apr 27, 2021 | 03:38 PM
WVZR-1's Avatar
WVZR-1
https://www.amazon.com/dp/B0049ZDORS...v_ov_lig_dp_it
https://www.amazon.com/dp/B000C9M4SA...v_ov_lig_dp_it
TIA
If yours is an 'original' I'd service what you've got vs purchase of a NEW from either of those you've linked. If you were interested in a 'performance increase' vs original I'd shop other than those mentioned also.
An original in '96 I'd think would be 10480202 KG9
Old Apr 27, 2021 | 03:50 PM
vette196's Avatar
vette196
The p/n you gave me at summit is the same as the O.E. one ($200+)
Mine has 90K miles on it and it is grungy compared to the other parts in the engine bay. I didn't want to mess with it cleaning it up, so I thought if I bought a "new" one I could polish it and hold the original as a back up.
What aftermarket brands are good? Why are they better than stock?
Thanks.
Old Apr 27, 2021 | 03:58 PM
WVZR-1's Avatar
WVZR-1
Thanks.
I meant - Does yours still have the original label with that part # on it or is it already a replacement of some sort? I didn't say and didn't intend to 'imply' better!
Old Apr 27, 2021 | 04:00 PM
vette196's Avatar
vette196
I'll have to dig it out from the parts table, I report back tomorrow. Thanks.
Old Apr 28, 2021 | 10:28 AM
vette196's Avatar
vette196
No numbers, but it says "delco remy" on the back
Old Apr 28, 2021 | 10:46 AM
WVZR-1's Avatar
WVZR-1
I mentioned 'label' but I believe OE would actually been etched/stamped (whatever) into the housing. You need to disassemble to 'make pretty' but for the $$ maybe an after-market build from a reputable reseller. There are a few!! It appears you asked back in 2018 regarding maybe the same alternators.
Old Apr 28, 2021 | 10:52 AM
vette196's Avatar
vette196
back then I was getting parts ready, polishing and what not. I do a damn good job with steel wool and metal polish, but with the openings on the alternator I was afraid to get pieces of steel wool inside the unit.
With a new/rebuilt unit I figured the case in clean and would just need some polish
\Now, I'm ready ($$) to put it all together
Old Apr 28, 2021 | 10:56 AM
WVZR-1's Avatar
WVZR-1
Buy a pair of housings, polish and have a 'local' do internals and assemble. I'd think less $$$ than either choice you mention. Housings $50 or less for both and quality internals are quite inexpensive. Talk to a 'local' regarding assembly if you want to avoid that.
To Two alternator options
