SBC Flat Plane
Old May 3, 2021 | 08:27 PM
arbee's Avatar
arbee
Default SBC Flat Plane
After reading another thread where the OP said he likes the sound of the new Mustang, I got to thinking. Did anyone ever develop a flat plane crank for the Gen 1 350? I see a couple of old articles where they claim one was "in development" but I don't see any info on if this ever came about. I may have missed it but I don't recall this ever being discussed here.
Old May 3, 2021 | 09:22 PM
84 4+3's Avatar
84 4+3
I recall this coming up last year sometime and there was a lone video of someone having basically a "barn find" of a true 180 degree one off chevy small block. I'm going to look for the thread and link it if I find it.
Edit: found the
Old May 3, 2021 | 09:44 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes, they've made flat plane cranks for SBC's. I have a few things to say about this b/c I find the current lust for flat plane cranks to be a bit annoying. (Not saying that you have a fetish for flat cranks, but many do).
In fact, Summit Racing has a SMOKIN' deal on one today!
Sounds like a typical 4 banger, to me....
Sounds like an air cooled, 80's 4 cylinder *** bike engine...
The sound of the Mustang with the flat crank, was engineered to sound good....and in doing so, Ford eliminated the one primary advantage that the single plane crank offers; even firing pulses on each engine side, and thus, perfect exhaust tuning with equal length headers. Likely, the GT350 sounded like a 4 cylinder poo with equal length primary tubes (as most all flat plane V8's do) so they change the primary tube length to get better sound...thus side stepping the tuning potential of the exhaust for that application.
You could get the same potential benefits (and awesome flat plane sound) by using (buying or building) equal length, 360° headers on any typical 90° crank V8. The result will be the same; 180° firing pulses coming out of each collector, and a sound much like that of an in-line 4 cylinder.
The only other benefit of the flat crank is it's lower mass and thus rotating inertia, which obviously "helps it rev more quickly". But how significant is this improvement? Minuscule to non existent. You could achieve much larger rotating mass reduction in the flywheel and clutch assy for way less money.
Old May 3, 2021 | 11:10 PM
FAUEE's Avatar
FAUEE
Not to belabor the point, but that lower rotating mass also allows for a rotating assembly to spin to a higher rpm without adding a lot more expense. That's why Ford used it for the gt350. Well, that and marketing. It's worth a lot more in marketing than outright performance... Still a gt350 is a very cool car lol.
Old May 3, 2021 | 11:20 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You're going to have to explain that one to me. The flat plane is more poorly balanced...IDK how that situates it to rev higher. Rev more quickly, yes. Higher? This guy don't "get it".
THIS. Marketing. It's worked, for that.
Old May 4, 2021 | 08:49 AM
84 4+3's Avatar
84 4+3
I'm trying to remember now but I believe the FPC is only poorly balanced on the second? order harmonic? Which will go away/be less evident with rpms. It is still even fire and because of that the loading across the crank will be even which makes it easier on it at higher RPMs. You can build both to run at 8k for sure. You just run into inherent issues with it such as displacement... as you go larger it gets harder to implement. I had friends have motors let out in the ford's. Granted the replacements have all been fine.
It's a cool design and has it's place. I don't fault people for liking it but in the average street car you don't really take advantage of its strengths. It's just cool to say you have one and if you like the sound it's cool too.
Old May 4, 2021 | 09:28 AM
FAUEE's Avatar
FAUEE
I'm far from an engine designer, but my understanding was just that it reduced the rotational mass, thereby allowing it to Rev higher assuming the same balancing was done. Essentially just that the lower rotating mass took less energy to spin. Thinking about it now, that makes no sense, as the engine would have more than enough power to spin the crank as fast as needed.
Old May 4, 2021 | 10:53 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Agreed. It's like saying that a heavy car won't have as high a top speed as a light car (all else equal/same). They'll both have the same top speed, but the light one can accelerate faster to the same top speed.
The flat crank offers a similar benefit...unfortunately the real benefit is very, small as compared to the mass and diameter of the flywheel and clutch.
Old May 4, 2021 | 11:01 AM
arbee's Avatar
arbee
Not sure I can agree with that. To clarify, are you saying that a 350 in say, a big boat Impala will have the same top speed as the identical engine in a Camaro or Vette, just the Camaro or Vette will get there quicker?
Old May 4, 2021 | 12:08 PM
PacerX's Avatar
PacerX
From the theoretical physics standpoint it's actually correct.
A bunch of real world stuff has to be ignored... Air resistance... Rolling resistance... Etc... But the theory is right.
As far as a flat plane just being marketing? No g*dd*mn*d way.
GM is, by all indications, about to spin a motor to the moon in the upcoming Z06 and they don't screw around... Getting GM to move away from OHV motors still hasn't happened because they make good engineering sense in spite of every idiot auto journalist calling them dinosaurs for it... There is no way on Earth they would go flat plane merely for marketing.
Old May 4, 2021 | 12:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No. I said:
"It's like saying that a heavy car won't have as high a top speed as a light car (all else equal/same)"
So we're talking the same car "all else equal/same"...but different weights. Same shape, body, aero, engine, ride height, but different weights...they'll go the same speed.
Old May 4, 2021 | 12:24 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Oh yeah?
Remember before the C8/mid engine was official? Remember what GM/Chevy's position was on the front/mid engine car?
What was that? Were they building a front/mid car b/c it really was better? It was ALL marketing. They told us one thing for the C5/6/7...then they built the C8.
People know Ferrari and other "exotics" have flat cranks. People know that race cars have flat plane cranks. People don't exactly understand WHY they do, but they have 'em, so they're better. There is for SURE, marketing equity in that and Ford exploited the **** out if it w/the GT350....the negated the actual benefits with the exhaust that they put on it.
EDIT: Did you know that the first production V8's all had flat plane cranks? Why?
"Most early V8 road car engines also used a flat-plane crankshaft, since this was simpler to design and build than a cross-plane crankshaft. Early flat-plane V8 engines included the 1910 De Dion-Bouton engine, the 1915 Peerless engine, and the 1915 Cadillac engine."
Old May 4, 2021 | 12:29 PM
arbee's Avatar
arbee
Still don't agree. NASCAR is a perfect example of your last sentence. Chase Elliott's Camaro is the same as William Byron's Camaro. They are measured by laser before every race. Same, same, same. They have rules requiring all cars be at least a certain weight. If the car + driver is not within specs, then ballast has to be added to reach specs. Gotta be a reason for that rule.
Old May 4, 2021 | 12:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
There is a reason. They go around turns. They aren't going flat out, straight line, to the car's absolute, drag limited, top speed.
Come on man...this is pretty basic physics here. Weight doesn't affect top speed. It affects acceleration.
Old May 4, 2021 | 12:42 PM
FAUEE's Avatar
FAUEE
I think the corvette vs impala comparison is the issue. The more accurate question and answer is impala with just a driver and a quarter tank of gas, vs impala with 6 big oil boys, a full tank, and a trunk full of bricks. Barring any ride height differences, they should.... Eventually... Reach the same top speed.
Old May 4, 2021 | 12:47 PM
FAUEE's Avatar
FAUEE
Oh yeah?
GM sold the C8 on" we reached the limit for what FR can do", then got embarrassed by a series of other cars setting lap records with FR drive trains. Then got even more embarrassed by the C8 being slower around a track than a C7 GS, despite a big power increase, a massive transmission improvement, and all that jazz.
GM went midengine for marketing, so they could try to go after the guys who could almost afford the exotics, but not really, and so the retiring 401k cash outs could tell themselves they made it and bought a mid engine supercar before they die. That's the only logical conclusion. If they did it for performance, then their whole engineering team should be fired, because they failed after a massive investment.
Old May 4, 2021 | 12:52 PM
arbee's Avatar
arbee
Chill out Tom. Sorry for asking a couple questions. Have a nice day.
To SBC Flat Plane
Old May 4, 2021 | 12:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Exactly. I totally
Now they're going to sell "sick bastard", exotic tech flat plane cranks to fan-folks. People are already bought in...even if there aren't meaningful real world advantages.
Old May 4, 2021 | 02:37 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hey, I'm relaxed. I just couldn't understand why we needed to rehash a basic topic like terminal velocity. We're good,
Old May 4, 2021 | 03:42 PM
bb62's Avatar
bb62
Generally this is true, but for the NASCAR example, extra weight does impact top speed due to the greater tire deflection in the heavier car (where in NASCAR everyone is using the same tire specs). The extra power that is required to offset the tire deflection cannot be used for top speed. In a sport like NASCAR where the differences between winning and losing are often razor thin, extra weight will negatively impact a competitor in top speed.
For flat plane cranks, please see the attached picture from "The Design and Tuning of Competition Engines" by Philip H. Smith (6th Edition). This might help some of the discussion.
