since he mentioned goes to battery I would think he is talking about the electric wires that go over the top of the cables,
if so I would think ecm power for the fiteck.
I agree !! The OP seems to have 'tricked' many/most. Seems maybe it's a recent purchase and the OP is very unfamiliar with his buy! The last snapshot indicates that.
I would suggest a call to FiTech customer support. Go over your car\kit situation and maybe they can provide the correct set up\operators manual for the kit you have.
..... What year is your car ? Is it supercharged ? Why are you concerned about the mysterious cable ? .....
84, yes. I'm doing maintenance on it, and I want everything double checked over before I put it back out. Took it to a shop for a tune, and poof when I went to get it the transmission is not working... it only shifts into 2nd when you let off the gas.
..... The TV cable is under the bracket and needs to be adjusted properly ... might be a little tricky to get at the adjusting tab since its not visible in your 1st pic ... the cable end is visible attached to the throttle lever under the bracket .....
Hmm, it seems tight like a guitar string at full throttle currently. I've been told thats correct, fluid is also correct (good color, filled). Are issues going to present themselves with incorrect tv cable resting position?
