spark plug change
Old May 26, 2021 | 01:14 PM
new2me92's Avatar
new2me92
Default spark plug change
is there any secrets i need to know when changing the spark plugs on my 92 lti corvette
Old May 26, 2021 | 01:21 PM
Nomake Wan's Avatar
Nomake Wan
The last plug on the passenger side, cylinder 8, will make you want to cry. It's hard to reach, the plug boot will likely fight you to the death before coming off, and you'll have a ton of fun trying to get the new spark plug angled correctly so that you can thread it in without getting a bunch of grime on it first.
The driver's side will make you want to sell the car.
I'm only half-kidding. If you're only doing plugs but not wires, then it's not all that bad. Just move the ASR and throttle cable mechanisms out of the way to make room, and remove the driver's side wheel well inner cover if you need more than that. The plugs aren't too bad, it's changing the wires on the driver's side that is awful.
Old May 26, 2021 | 02:13 PM
Beater12's Avatar
Beater12
Or you could do what I did. After reading all the horror stories I let the mechanic do it while doing some other stuff. He had done a lot of them and didn't even complain about it!
Old May 26, 2021 | 02:35 PM
AgentEran's Avatar
AgentEran
How much $$ is this option??
Old May 26, 2021 | 03:35 PM
Beater12's Avatar
Beater12
Not sure what it cost because I had it done with a lot of other stuff. Bill broke labour price down but not that specifically.
Old May 26, 2021 | 05:48 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Patience
Old May 26, 2021 | 06:33 PM
AgentEran's Avatar
AgentEran
whatever you do, dont force with a plug socket. You should start each plug (carefully) by hand then hand tighten. Once it is in there by hand torque to spec. Its absolutely no fun at all when you cross thread a sparkplug boss. Ask me how I know.
Old May 26, 2021 | 08:30 PM
95LT1ZF's Avatar
95LT1ZF
Yes. The back passenger side plug is a bear. Took my wife's small hands from under the car about an hour tobgetnit. The rest are pretty straight forward.
Old May 26, 2021 | 08:59 PM
Whaleman's Avatar
Whaleman
It is also fun when you drop the plug trying to start it in #8. Almost impossible to get it out. Dan
Old May 26, 2021 | 09:18 PM
Beater12's Avatar
Beater12
You got your wife to lay under your car for an hour putting a plug for you! She's a keeper!
Old May 26, 2021 | 09:25 PM
mark970's Avatar
mark970
The last plug on passenger side (#8) worked best for me with no extension and getting it loose enough to use my hands for the removal, baby turns basically.
Drivers side was super easy. remove the ASR box (1 bolt, in the wheel well) and the wheel-well dust cover so you can get straight access. I think for me, the worst one was either #4 or #6 (cant recall) but the control arm was in my way just enough to
really, not a big deal...just pay close attention to installing, don't force the thread and make sure the area is clean (good idea to use LP air prior to removal and blow out the dirt/sand/debris. Another tip is to go up a size on the plug wires. OE is 7mm but many people go up to 8mm. the only issue with doing this is the looms...the 8mm wires wont fit that great in stock "mounted" looms.
Not sure why people complain so much, nothing is "hard"...hard is relative...instead just accept that certain tasks are going to suck and just go for it and get it over with
Old May 26, 2021 | 10:58 PM
new2me92's Avatar
new2me92
thanks everyone for your input, after some deep thought i decided not to hang myself but take my time and be patient. wish me luck
Old May 27, 2021 | 07:06 AM
PacerX's Avatar
PacerX
There's a lot of winging that goes on about changing plugs in a C4...
They're really not that bad. I've dealt with much, much worse.
Just take your time, have a few different length extensions on hand, use an actual spark plug socket (so you can put a wrench on it if you need to), blow the pocket out before removing and restart them by hand.
Old May 28, 2021 | 05:35 PM
DGXR's Avatar
DGXR
You can do it! If your spark plug socket has a hexagonal backside, that is for a reason. Find a box wrench that fits it and this setup could make things much easier when access gets tight.
To spark plug change
