Callipers
Old Dec 16, 2002 | 10:59 AM
aroulette's Avatar
aroulette
Default Callipers
Can you just degrease and clean callipers and then paint them with a brush without removing them from rotors?
Old Dec 16, 2002 | 11:19 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default Re: Callipers (aroulette)
More than likely, but I'd rather take them off and do it right. :yesnod:
Old Dec 16, 2002 | 11:33 AM
aroulette's Avatar
aroulette
Default Re: Callipers (96LT4)
I'm not sure how compliccated that process is or if I have the right equipment
Old Dec 16, 2002 | 11:35 AM
xlr8nflorida's Avatar
xlr8nflorida
I would take them off completely and do it right but....
if you are not aware how to do this, you could probably do a pretty good job on the car. Just make sure you use a toothbrush or small brush to clean the surface, then use a high quality paint and you might want to tape up the rotors so you don't get paint all over the place, you also have to make sure you don't get any mist on the fenders.
Let us know how it goes.
Old Dec 16, 2002 | 11:43 AM
aroulette's Avatar
aroulette
Default Re: Callipers (xlr8nflorida)
I was going to use a brush
Old Dec 16, 2002 | 12:37 PM
35th's Avatar
35th
I painted my calipers without removing the brakes or rotors. Just take U'r time while doing the job and U should be alright :yesnod:
Old Dec 16, 2002 | 05:57 PM
CNTDRV55's Avatar
CNTDRV55
Default Re: Callipers (35th)
I used folia-tec caliper paint....it comes with small brush and cleaner. Its easy to paint while on the car. If you jack up car a little extra to get under, you can get at all angles. Good stuff.
[Modified by cgtarga1, 4:58 PM 12/16/2002]
Old Dec 16, 2002 | 06:22 PM
aroulette's Avatar
aroulette
Default Re: Callipers (cgtarga1)
Where did you get this stuff?
To Callipers
