Winter Projects
Old Dec 16, 2002 | 12:17 PM
35th's Avatar
35th
Default Winter Projects
What projects will U all be working on over the winter. Other projects or upgrades on U’r Vette’s. Here's what I'll be working on 4 the next couple of winters
:lol: My 1965 Caddy Convertible :yesnod:
[Modified by 35th, 11:19 AM 12/16/2002]
Old Dec 16, 2002 | 01:09 PM
stillthere's Avatar
stillthere
Default Re: Winter Projects (35th)
looks like fun. i will be doind some vette projects. mainly clean up and restoration. i want to pull out the rear suspention and polish the aluminum parts.
Old Dec 16, 2002 | 01:26 PM
c4md's Avatar
c4md
Default Re: Winter Projects (stillthere)
New convertible top, sending the shocks off for a rebuild, urethane bushings, fixing the intake manifold oil leak, plugs & wires, weatherstriping and lots of Zaino. :D
Old Dec 16, 2002 | 01:29 PM
n1kki6's Avatar
n1kki6
clutch, poly bushings, brakes, will need new tires, and hopefully if money is left over i will get a camber brace.
Old Dec 16, 2002 | 02:20 PM
Jimbo93's Avatar
Jimbo93
Am contemplating going with the "Hot Cam " kit. In the process of gathering costs.
Old Dec 16, 2002 | 02:41 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Winter Projects (Jim Holbrook)
In process - 383 stroker - block is at machine shop
1) Accel 219 cam and AFR 195 Heads
2) 1.6 Roller rockers
3) add SuperRam intake and plenum
4) Elderbrock high flow water pump
5) All new universals - expecting alot of torq.
Can't wait till the summer
:cheers:
Old Dec 16, 2002 | 02:45 PM
Ray8's Avatar
Ray8
Have a look in my signature
:cheers:
Old Dec 16, 2002 | 02:52 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: Winter Projects (Ray8)
I am putting on my reworked intake with the dividing walls cut back, polishing plenum and runners, installing nitrous system, as well as some electronics to go with that :smash: :smash:
Old Dec 16, 2002 | 04:29 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I need to finish building the new garage. Already have the BendPak HD12ss lift waiting to be assembled. *drool* Then the fun begins ->
On the 90:
Plugs/Wires, vac hoses & other stuff damaged in engine fire
Clutch
Hurst Shifter?
Clean underbody
On the 86 Vette:
Replace throwout bearing (someone put in backwards) :mad
Put in new window motors
Door panels
ASM Throttle body
Paint
Clean underbody
On the 86 Bird:
Fix blown brake lines
Look into 3.4L swap
I'm hoping to get the 90 and the Bird done by mid Jan. It'll be fun! My dad will do most of the work on the 86 by himself (except pulling the tranny - easier w/ two people).
Dale
Old Dec 16, 2002 | 04:34 PM
Storz's Avatar
Storz
Default Re: Winter Projects (Professor)
My winter project? Keeping my car clean cuz its my daily driver :D
Old Dec 16, 2002 | 05:48 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Winter Projects (Storz)
I'll be putting on a big brakes kit and also putting new weatherstripping on both doors and poly bushings on the swaybars. Not much but should keep me busy for a couple days. :cheers:
Old Dec 16, 2002 | 06:20 PM
StealDads67's Avatar
StealDads67
:iagree: Im with you
Old Dec 17, 2002 | 12:05 PM
35th's Avatar
35th
Default Re: Winter Projects (StealDads67)
Good luck with U'r projects. Good thing Christmas is around the corner, maybe some of these upgrades will end up under U'r Christmas trees :D
To Winter Projects
