I just bought an '85 C4 from a retired co-worker. It has 86k mi on it. He replaced the motor mounts, shocks/struts, radiator, heater core, all belts and hoses, brake lines and had the windows tinted - and I still got a good price on it; he was no longer to get out of it at 72 It runs pretty well although the throttle is sticky off of idle and from my research here I am going to start with a basic TB cleaning.and check of the cables/linkages. The engine runs very strong but the brakes are a little soft. I have lots to read up on and I am sure I can use some advice going forward. I bought a Haynes manual as well although I will take the bigger work to a shop - I just need to find a good Vette shop in town.
Going to move this to the C4 General section where you may want to expand on what your particular questions are - and this may be ultimately moved to C4 Tech.
