From: SCMR Rat Pack'r Charter Member..Great Bend KS
Buffer/Polisher
I'm looking for a good rotary (NOT orbital) buffer to work out some paint issues in my Silverado. Anyone have a recommendation on one that has worked reliably for you?
Thanks in advance.
I had already checked out Griot's buffers, which is what autogeek sells. I know they are good units, but a little pricey.
Still, thank you for the tip.
Are the Mothers 105 and 205 the best standby products to use for scratches? Which pads does one buy thats the one I cant find an answer to.
Best that you would find locally at just about every Autozone sure, but I use Jescar compounds and polishes. Menzerna also good.
I use Lake Country 5.5" CCB pads for compounding and polishing, you could also use Rupes which are great too. For heavy cut, MF pads from Meguiars are a good way to go.
For the rotary, I'd still point to Flex or maybe Rupes, if you can afford it, otherwise Milwaukee.
Unless you're just really short on time (ie a dealership hack), there is no reason to do a rotary vs a modern dual action polisher. At least not on a car.
I have both. Nothing cuts like a rotary. That being said that's generally why you never use it on paint unless you have to. The DA will get paint finished 80% of what a straight rotary will with the same effort and time. It will get it 100% with some extra time and not take off anymore than is required to get it the way you want it.
For the most part, the rotary is reserved for gelcoat now. But I did do my truck when it got overspray on it from the body shop that did the bedliner. Sometimes you just have to do a hard correction. But I digress. Both mine are very old and are no longer available. My DA is a porter cable unit from autogeek. I generally reach for the DA now. And as far as 105 and 205, yeah, they're a pretty good standby as far as anything I've had to fix.
I have two orbitals (DA's). One, a Porter-Cable, the other a Ryobi. For the task at hand, I need a rotary. I've done a good amount of body/paint work over the years and have a pretty good idea of what's going on.
Checked the Milwaukee's. They are pricey, especially considering that you have to buy the battery(s) and charger extra!
I am trying to avoid the Harbor Freight/Amazon Chinesium stuff, but.........
I use the Dewalt DWP849 For the money it gets the job done, although I rarely use it anymore unless I have a particularly stubborn marr or scratch to eliminate.
Have a few fine scratches that almost catch the nail...I was spraying some clear and overspray set up...dummy me took a clay bar to remove it and hood looks like an etch a sketch. Clear was too soft.
Compound or wetsand? dont meant to hijack
I am sure not qualified to use a rotary. I was scared of my orbital until I read a post here that said the only way you can hurt your paint with an orbital and polish is to take the orbital and smash it against the car. Since I am retired I look forward to polishing for 3-4 days (not long days) in March or so when it it still too snowy and cold to drive. I am lucky enough to have a nice heated Corvette garage. Dan
worst case I screw it up and respray it myself.
I'm not that much a pro to comment but if it was too soft I'd for sure wait... just do a test section with the mildest and work your way down until you're happy with it. That's how I check everything now. If wax doesn't work then I go for a wax/polish. Then usually 205 then 105 and if none of that works I just stop because I'm not qualified to get it out either.
