Fuel without Ethanol
Ethanol in the fuel tends to wear out rubber in fuel system parts, I'd never run it in a really old car where they'd still have used mechanical fuel pumps with rubber diaphragms and rubber connectors on all the lines. Also isn't good at all for a car that tends to sit a lot.
Given the number of fuel pump/sender failures I see on the forum now vs even 10 years ago in C4s, I do think that long term use of E10 ethanol is contributing, but
The Multec injectors used in the late 80s/early90s cars are such junk that it probably contributes there too, but they'd likely fail anyway.
Where else would they sell this much ethanol if not driven by an act of the government. Ethanol produces less energy than gasoline per gallon but has a higher octane rating thus lowering the price of high octane gasoline. Have you ever priced “race” gas? Pure gasoline that is usually 103 octane and the last time I had to buy it the price was a little under $9 per gallon just outside the Ron Fellows race school in Pahrump, Nevada.
That is why from 1995 on our Corvettes had fuel systems compatible with ethanol.
