Power Antena
Old Jun 22, 2021 | 05:56 PM
Corvette92386's Avatar
Corvette92386
Cruising
Default Power Antena
I have a 1987 Corvette and just installed a new power antenna and relay switch. The antenna seems to perform nicely going up and down except there's a loud buzzing noise that lasts about 3-5 seconds after the antenna is fully extended or retracted. I'm using the antenna with a stock Bose radio system. Any thoughts on how to correct the buzzing? Thanks.
Old Jun 22, 2021 | 08:24 PM
gdgeorge's Avatar
gdgeorge
Veteran: Marine Corps
Where is the buzzing from? Speakers? Driver's side rear?
Jerry
Old Jun 22, 2021 | 08:56 PM
Corvette92386
Cruising
Jerry
Jerry it’s coming directly from the power antenna. I can put my hand on the main body and feel the buzzing
Old Jun 22, 2021 | 08:58 PM
93QuasarBlue's Avatar
93QuasarBlue
you replaced just the mast or entire aftermarket motor unit?
Old Jun 23, 2021 | 07:52 AM
Corvette92386
Cruising
I replaced the whole unit with an aftermarket antenna from Corvette Central. They offer only one unit that is compatible. I believe all wiring incl the ground is wired correctly. I replaced the relay hoping that would solve the problem.
Old Jun 28, 2021 | 09:07 AM
bac22's Avatar
bac22
Sounds to me like the plastic belt in the antenna is slipping on the gears, I would return replace it...shouldn't be doing that.
To Power Antena
