1985 corvette
Old Jul 4, 2021 | 07:15 AM
Leecorvettec4's Avatar
Leecorvettec4
Default 1985 corvette
Help needed
my 1985 c4 corvette is driving me mad....
starts and runs fine from cold. Once up to temperature cuts out at idle and doesn’t restart. Only way to get it to restart is by spraying brake cleaner down the intake ( which I don’t like doing )
the car had a new fuel pressure regulator last year along with new fuel pump in the tank
thank you in advance for any advice. I’m desperate to get this car on the road again
Old Jul 4, 2021 | 07:29 AM
PacerX's Avatar
PacerX
Originally Posted by Leecorvettec4
Help needed
The standard advice is generally to start from the basics with a fuel pressure gauge at the Schrader valve and see what the fuel system is doing.
Old Jul 5, 2021 | 07:45 PM
don hall's Avatar
don hall
https://repairpal.com/ignition-control-module
Old Jul 5, 2021 | 09:32 PM
bartenderfloyd's Avatar
bartenderfloyd
This is a helpful guide https://www.corvette-web-central.com...etteStart.html
Old Jul 6, 2021 | 06:47 AM
Leecorvettec4
Thank you, very helpful link
i have not touched the car for a few days. I went to it about an hour ago and it started up after cranking for roughly 10seconds. It ran up to temp. Soon as the engine gets warm it still cuts out, I haven’t got a fuel gauge but I suspect the fuel pressure is not holding up. I did replace the fuel pressure regulator and the sender unit with new pump last year, I have a new set of fuel injectors which I will fit one evening this week. One of my mates commented the car sticks of fuel At the back like it’s over fuelling which is also leading me to think the injectors are going bad
has anyone else had bad injectors and had similar symptoms? Thanks again for your help
Old Jul 9, 2021 | 12:54 AM
xrav22's Avatar
xrav22
The Ignition Control Module can cut out when hot. Heat can screw up a lot of things. The ICM should be replaced if it is not known how old it is, Put new computer thermal paste under just a slight film will do it.
Old Jul 9, 2021 | 04:32 AM
ls777z's Avatar
ls777z
I would think that if the injectors were bad you would have an issue even at start up. Just because you replaced something doesn't mean you can automatically rule it out. Confirm that it is still functioning like it's supposed to.
Old Jul 9, 2021 | 07:26 AM
93QuasarBlue's Avatar
93QuasarBlue
I don't know if this relates to the 85 but it sounds like a problem in closed loop? O2 sensor or MAF?
MAF Sensor question ?? "1985 L98" - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Jul 9, 2021 | 07:35 AM
Leecorvettec4
Since my last reply I have replaced the injectors which has resolved the long crank time from cold it starts instant now but still cuts out when warm and idle goes rough. I replace the maf last year as I was having the same issue then still not resolved. Only thing I haven’t replaced is the icm and ignition coil
replacing the injectors has made the car sound like it has a different engine so I suspect my old ones were not 100%
i have booked the corvette into a American car specialist as I have reached my limit on knowledge, it’s possible something simple I’m not doing correctly however I’m not an expert when it comes to engines/ electronics
thanks for all your help and I will keep you informed with my progress
Old Jul 9, 2021 | 07:38 AM
Leecorvettec4
I have a ignition coil on order
Old Jul 11, 2021 | 08:29 AM
Skvitt's Avatar
Skvitt
Faulty TPS caused the same problem on mine.
Old Apr 20, 2024 | 09:18 PM
tppouncy@gmail.com's Avatar
tppouncy@gmail.com
1st Gear
Default help needed with headlights
I have replaced the driver-side headlight motor and the headlight will open but will not close. What could be causing this issue?
To 1985 corvette
