It should be simple, but cannot get it to change from only opening the drivers door, to opening both doors with the fob.
I put key in ignition, and hold door open button on fob, the doors unlock, if I keep holding it, I hear the cycling/relay, but doors don't actually lock and unlock.
Advice?
Advice?
I'm not sure what you are saying. With key in hold down the DOOR button, you should hear a clackclack sound. That should be it, it should have changed to unlocking one door to both, or vice versa. What do you mean about the doors don't actually lock and unlock? You aren't trying to lock or unlock the doors with the DOOR button are you?
I am doing what you listed, pressing door on key fob. Makes the sound, the passenger unlocks, then the clicking sounds. What I was saying is that the doors are not physically locking/unlocking (sliding lock lever back and forth once opened), was not sure if they should after the first unlock cycle. End result is it does not change, passenger door is still locked once car locks again after I walk up to car, only unlocks drivers door.
