Long term disassembly engine protection?
Old Jul 9, 2021 | 03:10 PM
Socalsalas's Avatar
Socalsalas
Default Long term disassembly engine protection?
I have A 94 6 speed that will be going up on blocks in August for a long time. I'll be dropping nearly every single component and fixing all rubber parts and seals and replacing many components. Many of these procedures required draining fluids.
my question is in regards to protecting those fluid filled cavities during a long period of disassembly. Especially in the coolant system, Where I know things can corrode fairly quickly. How can I protect these areas from corrosion during the time when it will be disassembled?
I anticipate that in total the job will likely take months. I can put off the jobs that will require draining fluids till the last possible time, but even then I think it will likely be awhile before filling it with fluids again. The coolant system has already been damaged by rust, So I suppose I should also ask how to repair the internal area cavities...
Are there any other considerations I should take into place regarding long term disassembly? Like how to store and care for components that will be removed and reinstalled later?
I want to be able to go very slowly, take my time, double and triple check, and not have any sort of deadline hanging above my head.
Old Jul 10, 2021 | 02:15 PM
FostersPerformance's Avatar
FostersPerformance
If they are engine parts you can soak them in fogging oil and put in plastic bags.
As far as cooling system goes, if you mean radiator, lay it down flat and fill it with fresh antifreeze. The rest should be fine for a few months. Clean parts before you store them helps too.
Old Jul 10, 2021 | 06:26 PM
Socalsalas's Avatar
Socalsalas
I was more concerned about the internal coolant cavities within the engine. I was told to drain the coolant, flush with water until clean and clear, then allow it to dry. Possibly with something like a blow dryer to speed that up maybe?
Old Jul 10, 2021 | 08:14 PM
AgentEran's Avatar
AgentEran
What are you afraid is going to happen?
Old Jul 11, 2021 | 09:58 AM
FostersPerformance
Yeah, nothing is going to get worse. Your fine. Just a chunk of iron.
BEFORE you re-assemble, go ahead and flush it out to remove the now dried stuff thats in there. Use compressed air as well. Take the 2 block drains out on either side of engine to flush out the junk in there.
Once back up and running, get some time/miles on it, and then do a coolant system flush if you feel the need to. After that good to go!
Old Jul 13, 2021 | 04:06 PM
Socalsalas's Avatar
Socalsalas
thanks guys. I was concerned about more corrosion occurring than there already is. I was told to flush it before disassembly and use compressed air to blow into the knock sensor cavities to speed dry it. Seemed logical enough
Old Jul 14, 2021 | 08:44 AM
arbee's Avatar
arbee
You are worrying about **** that don't need worrying about. As stated. it is just a piece of iron.
To Long term disassembly engine protection?
