Low Battery?
Since it seems to be charging at all I'd check the belt first.
You should be ~14.2 volts under power and no less than 13 at idle.
FYI, a (flooded lead-acid) battery (when disconnected) reading 12.2 volts is completely discharged. And, a (static) battery reading 12.6 volts is fully charged. If the voltage is below 12 volts, the battery is severely discharged. Furthermore, it is recommended that you NOT attempt to use the alternator to recharge a battery that is severely discharged as the load on the alternator is likely enough to possibly fry the rectifier too! Recharge the battery with a battery charger first. The alternator can handle normal loads like headlights, motors, and normal charging chores. But, a severely discharged battery or (worse!) a battery with a dead cell will tax the alternator beyond its intended design and it may damage it as well.Just went through this last week. Suddenly battery dead. With the doors shut and the under hood lights disconnected, measure the current between the battery post and the battery cable. (configure your VOM for measuring AMPERAGE according to the VOM's manual). Normal C4 static current drain is ~ 21-23mA (.021-.023A). More than that e.g., especially above an ampere of so will kill a battery over night.)
However, if you are not equipped to do the testing yourself, the recommendation to take it to someplace e.g., AutoZone or O'Riliey's, etc, where they can do a complete analysis of the charging and load testing of the system is the way to go.
