91 Power Antenna
Old Jul 13, 2021 | 08:24 PM
Beardeddan's Avatar
Beardeddan
7th Gear
Default 91 Power Antenna
Having hard time finding a replacement power antenna for a 91. Any ideas? Probably hard to find an original equipment replacement
Old Jul 13, 2021 | 09:31 PM
Nokones's Avatar
Nokones
Try Davies Corvette Parts. They may still have some OEM antenna assemblies in stock. Replace the entire assembly, not just the mast.
Old Jul 14, 2021 | 05:48 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
What exactly is the problem with yours?
If it's just that it fails to go up/down and the motor runs, you can replace just the mast and cable inexpensively. It's not a hard job to do.
Old Jul 14, 2021 | 09:12 AM
Beardeddan's Avatar
Beardeddan
7th Gear
Thanks. That's what I'm looking for, to replace the whole unit.
Old Jul 14, 2021 | 09:22 AM
Nokones's Avatar
Nokones
It won't be fun to install. Also, get a new grommet too.
Old Jul 14, 2021 | 09:36 AM
Red86Z51's Avatar
Red86Z51
I didn't think the job was bad at all. Remove the rear wheel & wheel well housing and everything is easily accessed. Agree on the grommet replacement.
Old Jul 14, 2021 | 09:00 PM
aklim's Avatar
aklim
Did you first try to rub lube on the shaft and polish it and see if it rises?
Seriously, it is a bit difficult to get the ground if you install the antenna. IIRC, you should get everything close, ground it and then bolt it up.
To 91 Power Antenna
