I need someone to walk me thru running a toggle switch from my secondary cooling fan. Where to run wire from what wire to tap into etc. I know nothing about it. Thanks for your help
c4
It doesn't come on at all. I would really appreciate someone to walk me thru step by step what to chk and where it's located. I know nothing about this !! Thanks y'all!
Kevin
I think if you jumper the terminals like you would when you are reading codes it causes both fans to come on? Someone please confirm. If so, maybe the you can see if it doesn't work and why?
c4
Help us, help you. "c4" doesn't help us, much. C4 was made for 13 years, had 5 different engines, two different fan configurations with multiple control devices and strategies. Year would help a lot.
Basically, ground the fan relay through your toggle switch. If you know where the fan relay is.
