Reading codes on a 95
Dec 18, 2002 | 04:49 PM
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Is there a way to use the "paper clip" trick to read codes on a 95? I have the 16 pin connector and all I can find is instructions for the 12 pin.
Glenn
Dec 18, 2002 | 05:37 PM
Re: Reading codes on a 95 (gdarwin)
Someone here on the forum has a website with instructions to do this because I was looking at it on Sunday. I have the site written down at home so I'll post it for you tonight when I get home.
Dec 18, 2002 | 06:17 PM
Dec 18, 2002 | 06:32 PM
Cruise-In I Veteran
Re: Reading codes on a 95 (lou sylvestri)
Been there. They don't cover 95. :confused:
Dec 18, 2002 | 06:43 PM
Cruise-In I Veteran
Found this site:
http://www.techweasel.com/articles/troublecode/GM.htm
This article says to short pins 5 and 6. When I do this the fans start up and the one to four indicator comes on.
Battery and check guages came on also, 11.4 volts indicated. I think this should be normal since tha car was not started.
Anyway the check engine light did not come on and did not start flashing any codes....
Dec 18, 2002 | 07:15 PM
http://forums.corvetteforum.com/zerothread?id=435278
Give the above thread a look :thumbs:
P.S. I should acknowledge that I got the info I posted in that thread from Lou Sylvestri! :yesnod:
[Modified by Lone Ranger, 6:18 PM 12/18/2002]
Dec 18, 2002 | 08:42 PM
Cruise-In I Veteran
Re: Reading codes on a 95 (Lone Ranger)
That did the trick.. :) Thanks!
Only code showing is C12. On to the next step to figure out the misfire. Plugs and wires next. I'm pretty sure fuel pressure is ok, but will check it also.
64,000 - might end up replacing opti and water pump....
:seeya
Glenn
Dec 18, 2002 | 08:49 PM
gdarwin
I's covered. Go to facts sheets,Code recovery & scroll to bottom. Techweasel posted a very good site. 94 & 95 shud be the same. You have to ground 12 to 4 for ECM/PCM codes thru the CCM. 5&6 are for the LPTWS.
[Modified by lou sylvestri, 5:50 PM 12/18/2002]
[Modified by lou sylvestri, 5:57 PM 12/18/2002]
Dec 18, 2002 | 09:26 PM
This is the site. They recently updated it and it covers '95's,
http://www.c4vettes.com/codes.htm Looks like you already figured it out though
Dec 18, 2002 | 09:38 PM
Cruise-In I Veteran
Re: Reading codes on a 95 (Thumper)
You are right... I was there and never even looked at that page..
G.
