C4 can’t go into reverse
Old Aug 10, 2021 | 07:55 PM
J0hnalex's Avatar
J0hnalex
Cruising
Default C4 can’t go into reverse
So I resintalled my transmission and hooked up the shift linkage and when I pull up on the color of this shifter I can’t feel like gate for reverse! Please help I’m out of ideas!
Old Aug 10, 2021 | 08:12 PM
Siveck's Avatar
Siveck
When you say shift linkage, I assume 4+3. Linkage needs adjustment? Place in neutral and try to even everything up by adjusting sleeves. Sorry I can’t help further, it’s been 10 years since I adjusted a 4 speed.
Old Aug 10, 2021 | 10:02 PM
J0hnalex's Avatar
J0hnalex
Cruising
I actually did figure out the problem! And I hope this thread will find someone who needs it in the future! Yes. It’s a 4+3
The linkage connecting to the transmission originally was disconnected. so my brother and I, mostly my brother was underneath the car slowly adjusting first and second, then third and fourth to where it felt comfortable coming in and out of ear on the shift lever itself. but then when we tried to figure out why the reverse rod was not moving we decided to dig a little deeper into the interior of the car!
I removed the center bezel around the radio a few screws on the dash to loosen everything up along with the screws that hold the small plastic panel in front of the passenger seat. Then removed all of the screws holding down the center consul. Then painstakingly figure it out how to remove the push button overdrive, unscrew the shifter, and pull the entire center consul and shift boot up and out of the way.
once we were able to see down inside of me shifter mechanism itself, there was a rod that was connected to the back of the shifter that goes to a table that bed behind the HVAC controls that goes up and into the steering column.
I did a little digging online and found out that that is called the reverse lockout cable. The only one that I found available was $300 on eBay which in my opinion is a little ridiculous. I disconnected the eclip holding the rod to the shifter. And wouldn’t you know reverse actuated correctly, and verified that the reverse rod going into the transmission actuated normally with no binding.
i’m assuming that the reverse lockout was placed there originally to prevent you going from 1st to 2nd and by accident going into reverse if you were shifting quickly you’re not paying attention to where your hand was on the collar.
has anyone disconnected the reverse lock out without any issues? Considering how much the replacement part was I think I’m going to try it for now until either it bothers me or some other issue happened because of it.
thanks everyone -Johnny A
Old Aug 10, 2021 | 11:03 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Nice work. Thanks for posting your solution
Old Aug 11, 2021 | 07:54 AM
jmeyer58's Avatar
jmeyer58
The cable to the column is designed to force the driver to place the car in reverse before removing the key. It prevents you from turning the key all the way off and locking the steering column while driving forward. If you disconnect it, you will not notice a difference unless the column sleeve rotates, then you would not be able to remove the key without manually rotating the column sleeve. Think of a car with a column shifter and when you place the car in park the key can be removed.
To C4 can’t go into reverse
