New guy question
Old Sep 3, 2021 | 04:05 PM
CBrunen's Avatar
CBrunen
Cruising
Default New guy question
Hey all, been shopping for a C4 for the past few months. I've seen a number of cars, however, they have all had what feels like a lot of play in the steering column. If you pull down to the left, it shifts the wheel pretty substantially in my mind. My buddy has a C3, and that wheel doesn't move at all, just like a modern car. My question is - in order to be comfy that I won't have to replace a steering column, should it have no play at all? I know this is a soft spot on these cars, but I don't have enough experience to know what is acceptable and what needs attention. Thank you in advance. - Craig
Old Sep 3, 2021 | 04:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
It should have none..or the tiniest bit. Its from lazy people lifting themselves out. Its not the funnest repair.
Old Sep 3, 2021 | 04:47 PM
CBrunen's Avatar
CBrunen
Cruising
Thank you cv67, that's what I suspected, but I've looked at around 15 cars and I'm starting to question my sanity.
Old Sep 3, 2021 | 04:53 PM
Fiberbundle's Avatar
Fiberbundle
As mentioned there should be no play. The knuckle that provides the tilt capability is made of aluminum but the hinge pin is steel. Guess what wears first. Repair parts are less than $150 but the repair involves removal of the steering column and disassembling the area around the knuckle. Not a bad job but some small parts that need to be finessed perfectly when reassembling the column.
This is a very common issue. I have done it before and it is 6-8 hours if you know what you are doing.
Old Sep 3, 2021 | 05:32 PM
SJW's Avatar
SJW
And when you find a C4 that has a tight tilt mechanism (or after you repair yours), do NOT use the steering wheel to help you into or out of the car. That is what most often damages these mechanisms. They are not robust enough to support the weight of your body.
Live well,
SJW
Old Sep 3, 2021 | 05:59 PM
CBrunen's Avatar
CBrunen
Cruising
Thanks Fiberbundle. That's a job that doesn't appeal to me. I'm very mechanically inclined, but my auto repair experience is extremely limited.
SJW - thanks, I watched Brad Hansen's video, and it's not too bad getting in and out, even at 46 with a fused spine.
To New guy question
