Moisture absorbant?
Old Dec 21, 2002 | 10:14 AM
95AquaC4's Avatar
95AquaC4
Default Moisture absorbant?
I have a condensation problem in my vinyl garage. What would act as a good inexpensive moisture absorbant?
Old Dec 21, 2002 | 10:54 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Moisture absorbant? (95AquaC4)
Home Depot sells little buckets of something that absorbs moisture, my buddy uses like three of them in his garage.
Old Dec 21, 2002 | 11:13 AM
JB666's Avatar
JB666
That and a good vapor barrier might help. I used a nice Burlap type material, Urathane coated and Water Resistant over my insulation and it seems to have cleared the moiture problems up......
Old Dec 21, 2002 | 11:41 AM
95AquaC4's Avatar
95AquaC4
Default Re: Moisture absorbant? (Jbaker)
Actually, I called the manufacturer after I first got it. They suggested a vapor barrier, which works great until a rain and the end with the door gets wet. Two days later...BIG condensation problem. I have electric in there too. So, I need something to act sort of part time when the floor is damp.
Old Dec 21, 2002 | 12:05 PM
95AquaC4's Avatar
95AquaC4
Default Re: Moisture absorbant? (Mr Mojo)
Thanks...Home Depot has been added to weekend errands list! :yesnod:
Old Dec 21, 2002 | 06:17 PM
95AquaC4's Avatar
95AquaC4
Picked it up...it's called Damp Rid. Let you know in a few days how it works! Hmmm... just realized...I quoted myself!! :crazy: :crazy:
Old Dec 21, 2002 | 08:07 PM
Juliet's Avatar
Juliet
Also check out boat stores. We have dehumidifiers in the boats which are on the lifts at the dock all winter. They run on 110V electric and have little fans. Every few weeks you pour the water out of the catch basin. Works great! The key is circulation. :yesnod:
Old Dec 21, 2002 | 10:21 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: Moisture absorbant? (Juliet)
That is what I was fixing to suggest...a dehumidifier...those you can empty every so often and just keep using them....The bags you buy at Home Depot have to be regenerated before you can use them again.
Old Dec 21, 2002 | 10:42 PM
JB666's Avatar
JB666
Those work OK, in small areas, but when your talking about some serious humidity, they won't pull it all into that little bucket... We have a 40' mobile home that we use to travel in the summer, and when I winterize it I always use about 4 of those Damp Rid containers and they are FULL within a month....
Jeff
Old Dec 22, 2002 | 06:35 AM
JHammer's Avatar
JHammer
I've been using Sta-Dri for the past 5 or 6 years and that's worked well for me. I got them from Mid-America (Part# 100-840). They're kind of pricey though... 4 - 2LB bags for $30. I dry them out each year in an oven before putting them in the Vette so if you factor in that they are reusable maybe the price isn't so bad.
To Moisture absorbant?
