Checking ESC module
Old Sep 24, 2021 | 05:31 PM
ps374's Avatar
ps374
Default Checking ESC module
I am having some trouble understanding the FSM on checking the Electric control module. The FSM says to check circuit C 485 with a volt meter. I am not sure what wire I should use as a ground. I also understand the car must be running. I do not want to cook the computer so I am a little nervous about this test. I got a oft 43 code. It says I must show 6 volts or better. TI have checked just about every sensor or replaced every sensor. At WOT I get hesitation. It is only at WOT. Car pulls fine otherwise. Fuel pressure shows 12 at the fuel filter. Coil and ignition module shows proper voltage. It is a 1984.
