92 c4 power distribution
Old Oct 11, 2021 | 03:12 PM
Lukethemaniacmechani's Avatar
1st Gear
Default 92 c4 power distribution
HI , I am helping my buddy with a 92 c4 the problem i have is the engine he got with the engine harness is a 93 with the 2nd auxiliary fuse block on the engine harness . I need the pin layout and diagrams needed to use the 93 engine harness on this 92 everything seems to just plug in but i know that the auxiliary fuse block has fuses for ecm, rear def, fuel , ign ect... which all these systems got power from 1 location through fusable links do i need to find each of these systems fusable link and tie them into the aux fuse block or just the systems that aren't on the engine harness i'm sure there is someone out there who has done this and can make it a lot easier for me. i can probably figure it out but would appreciate any help i can get either with pdf diagrams etc.. thank you
