Aldl
Old Oct 18, 2021 | 05:22 PM
Driver666's Avatar
Driver666
Cruising
Default Aldl
Can someone help with this problem, when i put the paper clip in the proper tabs in the ALDL t check for codes, I get nothing. Why would that happen?
Old Oct 18, 2021 | 05:24 PM
WVZR-1's Avatar
WVZR-1
What year and what pins!!! It all matters!!!
Old Oct 18, 2021 | 05:58 PM
Driver666's Avatar
Driver666
Cruising
1994 LT! corvette, 12 pins,,
Old Oct 18, 2021 | 06:20 PM
WVZR-1's Avatar
WVZR-1
You mentioned tabs, I assumed you meant 'terminals' BUT you mention using paper clip as jumper! I asked what pins(terminals) and you reply with 12.
Review this quite complete document for what you're attempting and TRY again!
https://tech.corvettecentral.com/201...trouble-codes/
Rather than paper clip buy a few correct Metri-Pack 150 Male terminals and fabricate a more suitable 'jumper'.
Old Oct 18, 2021 | 07:35 PM
Driver666's Avatar
Driver666
Cruising
Correction, I meant to say OBD1 wont respond to the paper clip method to check for codes.
Old Oct 18, 2021 | 07:37 PM
Driver666's Avatar
Driver666
Cruising
Top right terminal and bottom left.
Old Oct 18, 2021 | 07:39 PM
WVZR-1's Avatar
WVZR-1
There are specific instructions in that document for '94 + C4. You car has 16 pin connector and you need to use the DIC and IP cluster display to do diagnostics. It does very well!! Read again!!
Old Oct 18, 2021 | 07:40 PM
WVZR-1's Avatar
WVZR-1
That is wrong for '94!!
Thanks for the link helps alot, I have the wire connectors in the pic,but I dont get a response from the car. I did early . but now nothing.
If you're jumping wrong terminals it's difficult to tell what you might have done!!
Old Oct 18, 2021 | 07:41 PM
Driver666's Avatar
Driver666
Cruising
To Aldl
