What's that sensor called?
Old Oct 30, 2021 | 02:10 PM
controlu's Avatar
controlu
Default What's that sensor called?
1987 C4: Two sensors on the front of the engine just to the right of the fuel lines going into the fuel rails. The sensor on the right has a yellow and black wire going to it, and I believe that is the Coolant Temp. Sensor. The sensor to the left of that, with the screw driver resting on it, is the one in question. I’m trying to restore this Vette and I’m replacing things as I go because I don’t want to have to go back after I’m done. What sensor is that? I can’t get a new one if I don’t know what it’s called. The wires come out of the passenger side injector wire harness.
Old Oct 30, 2021 | 02:17 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Thermo time switch.
Old Oct 30, 2021 | 02:19 PM
Natty C's Avatar
Natty C
For the cold start injector. It stays closed for a few seconds on a cold start, then it stays open.
Old Oct 30, 2021 | 04:40 PM
controlu's Avatar
controlu
Thank you. I wish there was a source for that info. I checked two manuals and could find nothing.
Old Oct 30, 2021 | 04:49 PM
WVZR-1's Avatar
WVZR-1
What sort of information are you looking for?
There's very likely 50+ references for 'cold start' in the 6E-3 section of the FSM.
6E3-A-22 would be a very good start. If your FSM is a .pdf try page .pdf 416
Old Oct 30, 2021 | 04:59 PM
ajp01's Avatar
ajp01
I'm guessing those were Haynes manuals?
Old Nov 1, 2021 | 01:50 PM
controlu's Avatar
controlu
Thank you, I found the page you mention. I'm still learning the manual and finding new stuff every day. That cold start injector is a very expensive item!
To What's that sensor called?
