headlights
Old Nov 17, 2021 | 02:12 PM
hmart55's Avatar
hmart55
Default headlights
My sons 1992 has dull headlights. What is the best replacement or upgrade for the lights.
Old Nov 17, 2021 | 02:46 PM
JD1964's Avatar
JD1964
Used these in our 79 Malibu and they are very nice. Good coverage where the light should be without blinding other drivers
Amazon Amazon
Old Nov 17, 2021 | 03:26 PM
skybolt31's Avatar
skybolt31
I used these on my '95 and liked them, didn't seem to blind other drivers.
Amazon Amazon
Old Nov 17, 2021 | 03:42 PM
novaks47's Avatar
novaks47
Here's another option, if you prefer to stick with halogen : https://www.summitracing.com/parts/HLA-003427811
I run those with some Philips Xtra-vision bulbs, and it's much better that stock. They're not knock-your-socks-off amazing or anything, but still loads better than stock, and actually usable for night driving.
Old Nov 18, 2021 | 03:38 PM
jmeyer58's Avatar
jmeyer58
I am a big fan of the GE Nighthawks. Pattern almost matches the wife's CT-6 LED's
High Beam
Low Beam
Old Nov 18, 2021 | 08:58 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have these also, and I really like them. Well worth the expense.
Old Nov 19, 2021 | 09:31 AM
pedricd's Avatar
pedricd
I have the same, installed this year, night and day difference (pun intended). After 91 (? is that right?) you have to do a mod to make the high beams and fog light circuit play nicely together. I did the circuit doctor fix (search forum), it took maybe 10 minutes to do the mod (which only affects one of led headlight pigtails) and am super happy with the results!
Old Nov 19, 2021 | 09:35 AM
WVZR-1's Avatar
WVZR-1
Is this the mod/fix you're referencing?
https://www.corvetteforum.com/forums...-solution.html
Old Nov 19, 2021 | 09:42 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Best bang for the buck is Hella H4 glass lenses with 80/100W H4 bulbs.
You can get both from places like Jeg's.
Bolt in, but minor electrical connection changes required.
pedricd's Avatar
pedricd
yes, yes it is, thank you for dropping it in here . The explanation is very elaborate and tends to scare people off with "this is waaay too complicated I'll just order resistors". It is a super simple thing to do, more compact, cheaper, less heat than a resistor and guaranteed to work.
Old Dec 15, 2021 | 11:43 AM
65GTO's Avatar
65GTO
It all seems pretty pricey to me. Over $500 bucks for 4 headlights ??? I'll have to revisit what I did for my dune buggy 2 years ago. Got H4 lens housings (non-Hella.. way less $$) that also included a halogen bulb with each. They were like $15. I tossed the bulbs. On amazon bought H4 direct fit LED bulb replacements. They were like $30 for 2. They directly replace the H4 bulb... plug right in.. wires the same and all. All done was less that $60 bucks and 15 min work with a Philips screwdriver. Light up the road like crazy.
Old Dec 15, 2021 | 01:28 PM
ajp01's Avatar
ajp01
Low Beam
On 1989 and earlier, can these be used without any changes to the grounding / fog light / relay thing? In other words, they work right out of the box with no wiring changes? I know on 1990-ish and later cars there was an issue with the filaments being used to ground out one of the other relays for fog lamps, but I'm not sure on 1989 and earlier cars?
Old Dec 17, 2021 | 06:18 PM
FAUEE's Avatar
FAUEE
I'd ue the Morimoto led ones if I was doing it over again. I have the "osram" Amazon ones, they're OK, but the beam pattern on the Morimotos is better. Beam pattern is largely what you pay for in led headlights like this nowadays.
Old Dec 17, 2021 | 09:35 PM
belairbrian's Avatar
belairbrian
Just a note, the ones linked in this post are NOT legal on US roads. the US version is https://www.summitracing.com/parts/hla-003427291
Old Dec 18, 2021 | 08:06 PM
novaks47's Avatar
novaks47
True, but ECE lights are usually superior to their US counterparts, as ECE is far more strict across the board, and for the most part, produce superior beam patterns(you can even see the difference in lens fluting between the two C4 Hellas). If you're in a state that has inspections, then yeah, you're stuck with the DOT stuff. Otherwise, E-code all the way. I'll bet event the DOT Hellas are better than stock though, so I doubt one could go wrong either way.
To headlights
